![]() Enthusiast ![]() ![]() Joined Apr 4, '06 From Minnesota Currently Offline Reputation: -1 (0%) ![]() |
my gauge cluster isn't working no more. i took out my white face and now the pins wouldn't move? anyone know why? help fast! thanks
This post has been edited by fastcelica20: May 9, 2006 - 7:54 PM -------------------- ![]() |
Enthusiast ![]() ![]() ![]() Joined Aug 14, '05 From St. Paul, MN(USA) Currently Offline Reputation: 8 (100%) ![]() |
did you check your connector that connects to the cluster???if not that then you might have a bad cluster...if not that then check your speed sensor on your transmission...
QUOTE(team_omega @ May 7, 2006 - 1:29 PM) [snapback]431119[/snapback] did you check your connector that connects to the cluster???if not that then you might have a bad cluster...if not that then check your speed sensor on your transmission... i know it can't be my sensor. it was great before i took the white face off. after that it wasn't working. i went and got new fuse 7.5 and intalled and the rev meter and the oil/temp started to work. but the speedo didn't work. im very pissed. could it be anything else? the connector is good. can't be a bad cluster i tell ya -------------------- ![]() |
good news and bad news. i fixed it but now the interior lights are dead! i replaced it but no work! anyone plz help me!!!!!!!!!!!!!!!!!!!!!!! this is the worst day of my life!!!!!!!!!!!im stuck in the dark the only thing that lights up are my cd player and my dvd dash in my car. crap someone help! my car is dying,,,
make sure the dimmer switch is plugged in properly.
QUOTE(Batman722 @ May 7, 2006 - 10:56 PM) [snapback]431339[/snapback] make sure the dimmer switch is plugged in properly. where is the dimmer switch located? ill try to change the fuse also. i think fuse #10a -------------------- ![]() |
mornin' bump
no one knows? -------------------- ![]() |
sorry, the dimmer switch is located to the left of the steering wheel. It is a round knob.
tried that didn't work. could it be my fuse then?
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 6, '06 From massachusetts Currently Offline Reputation: 30 (97%) ![]() |
QUOTE(fastcelica20 @ May 9, 2006 - 4:26 PM) [snapback]432029[/snapback] tried that didn't work. could it be my fuse then? I had the same problem. I checked all of my interior fuses and changed a couple of them, that worked. Hope that helps. Dont forget to check the ones under the hood. This post has been edited by massbrandon: May 9, 2006 - 4:29 PM |
well i shouldn't be checking the ones on my hood cause they're lil' different. i checked the one under my steering wheel and checked "gauge" light. i think i might have to change the 10a fuse because when my previous owner put in the indiglo gauge, she put the red wire in the fuse. kinda confusing but yeah that's how it was pulled out. i think its bad. ill change and tell you guys if its the fuse or not. thanks batman and massbrandon.
ok i found something weird. here are some pics:
![]() ![]() here's the problem. i found two similar wires. the two that has the white swirlies. what's the other one for? one is fat and one is skinny and long. batman/coomer/people help! i drove in the dark yesterday from school and was scared to death. no interior lights at all. that was the only car i have. btw, yesterday was raining like crazy even my wipers couldn't help me on the highway ![]() This post has been edited by fastcelica20: May 9, 2006 - 8:05 PM -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jun 19, '05 From New York Currently Offline Reputation: 1 (100%) ![]() |
u check fuses??
QUOTE(TheStreetzKing @ May 9, 2006 - 8:54 PM) [snapback]432175[/snapback] u check fuses?? yup. i replaced the red ones which are the 10a and also replaced the 7.5a fuses. nothin lit up? the red ones are mostly for the interior lights such as gauge lights and heater lights and such. now i dont know what else to do? does the relays have anything to do with it? -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) ![]() |
look for the "DOME" fuse under the hood.
i replaced that. here's the problem. i have a 95 and my motor is a 96+ with the 5 extra hp. is that the problem then? im so so so so so so so so confused guys.
![]() Enthusiast ![]() ![]() ![]() Joined Apr 4, '05 From ST PAUL, MN Currently Offline Reputation: 3 (100%) ![]() |
ok yeah i had that problem once when i install my ground kit...the whole interior gauges didn't work at all..check the fuse box under the hood..check the main fuses..the fuses that you have to remove srews and stuff..i woul dcheck mine but its like 12 midnight...
ok i put in my white gauge face back in. the lights are working again. now im really confused cause it can't be the fuse. must be some sort of wire problem. but oh gosh this is killing me.
![]() Enthusiast ![]() ![]() Joined Feb 3, '05 From USA/Virginia Currently Offline Reputation: 2 (100%) ![]() |
so these white gauge faces are just pieces of plastic, right? nothing else to them like indiglo or anything?
also do/did the climate control and cigarette lighter light up? if you're going to spend a bit of time troubleshooting this then you might want a temporary work-around. maybe duct tape some keychain leds to the steering column to illuminate the gauges while you're trying to get things to where you want them. |
![]() Enthusiast ![]() ![]() Joined Jan 21, '05 From NY Currently Offline Reputation: 0 (0%) ![]() |
There is one more thing that might be wrong.
Check out whats up with ur gauge dimming thing (its a knob that regulates how bring ur interior lights are) if its disconected or brken all the interior lights will be off. -------------------- <<AKA THA RUSSIAN>>
Lo-Fi Version | Time is now: February 20th, 2025 - 2:48 PM |
