7 Pages V   1 2 3 > »
> YES 3sgte with a 5s stock tranny., some thing is broken. woot.
post May 7, 2006 - 11:31 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
well driving home on the mass pike i just cruising at 70mph in 5th gear at 3.5k rpm. when all of a sudden my RPM raises without me even touching the gas and now i down shift like wtf. and yeah every gear my car doesnt move. the clutch doesnt sound like it engageing at all. woo to pulling the motor again to find the problem.
first ill check thing like the slave cylinder ect. but im so confused cause i dont hear any moving parts when i shif an let the clutch out. i cant feel anyhting in the pedal at all. /rant ps this sucks.
im hoping my clutch setup is ok and that my flywheel bolt havent sheared off or worse.
post May 7, 2006 - 11:40 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
Check for fluid. Check the slave cylinder is working properly
I will return one day.
post May 7, 2006 - 11:41 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
fluid is full 2nd thing i checked for. yeah i plan on checking the slave tommorow.
post May 7, 2006 - 11:45 PM
well ... its a clutch issue for sure. nothing wrong with your trans.
did u changed the clutch when you swaped? what did u put in there? did you brake it in when u installed it?
post May 7, 2006 - 11:48 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
id agree with you but no bad sounds come from the tranny area at all. its a spec clutch rated for 420ft/lbs torque. broken in properly over 500 miles. its weird i dont hear any grinding or metal ratteling. confused. cause i mean if a clut breaks i assume you feel and hear it when it does. this is quiet as ever.
post May 7, 2006 - 11:57 PM
i know your problem !
check your axels. one of them broke or fell out.
post May 7, 2006 - 11:58 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
im not exactly an expert like some of these guys but what about your shifter cables?
edit if his axles fell out wouldnt he be dripping heavy duty transmission oil everywhere?
This post has been edited by brianforster: May 7, 2006 - 11:58 PM
post May 8, 2006 - 12:01 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
no clue but i know no fluid is leeking my cv might be busted also. shifte cables was the first thing i checked while on the side of the highway tongue.gif
post May 8, 2006 - 12:04 AM
yes thats if it fell out. the cv could have gone too, and the axels would still be in there.
i had the same thing happend to me. thought it was the clutch too and it was the axel.
post May 8, 2006 - 9:12 AM
bigal004321
Joined Jun 21, '05
From New york
Wouldnt it be more likely that the axle would break under heavy strain, like at the track. I mean he was just driving a constant speed, seems a little hard for an axle just to break like that, and if it does then i am scared for my axles after this swap.
Bigal
1994 celica GT.....3sgte in a month! all helpers are welcome!!! i live in Plattsburgh, NY.
post May 8, 2006 - 2:19 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
well today i put the car up on jack stands and started the car and both wheels spin but very slow and rpm doesn't influence speed. also with both tires off the ground not running if you spin one tire the other spins the oposite direction like it should but you can easily stop the rotation on the other wheel just by holding it. basicly its not an axel cause we checked them we think somthing in the clutch assembly did break. wether it be the disc of where the disc connects to the tranny splines. so i have to pull the tranny out again... so not happy about this. oh well the celica will be off the road for a while and im gunna turn it into more of a show(engine bay)/track car than a daily but come next year when everything is done i will be a show winner i hope. while the motor/tranny is out im gunna clock the turbo, get 3'in intercooler pipe, new FMIC and powder coat/ ceramic coat abunch of under the hood parts. also if i find a cheap 3sge tranny id buy it in a heartbeat.
This post has been edited by x_itchy_b_x: May 8, 2006 - 2:25 PM
post May 8, 2006 - 2:26 PM
you mean, downpipe,right?
why? you have a problem with your clutch, not your tranny.
im really surprised to hear that your axels are ok. did you get under the car and really inspect them well, or just go by the fact that the wheels were spining?
post May 8, 2006 - 2:32 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
well my tranny i do have slight problems with. cruising speeds. tops speed. the syncros are going out. so eh. i inspected them pretty well. once i make some room in the garage ill pull them out. but we can hear a grinding noise coming from the clutch housing so thats what we really expect it to be. and its not the normal spec clutch grind/tick people normally hear.
no 3" intercooling pipe, i remeber reading a post on mr2oc that they gained like 12 hp.
its not much but i plan on going to a larger turbo in the future so i might aswell build up everything i can now so im 100% ready to make more power later. i plan on having the car off the road till next year so ill have plenty of time to play with everything.
post May 9, 2006 - 6:25 AM
john, dont do the 3" piping.
with our length, and your powerlevels, all your gonna do is add a ton of lag.
post May 9, 2006 - 8:50 AM
burneeed
Joined Dec 18, '05
From BANNED
s54 not a good tranny for the 3sgte. Lots of people will vouch for that including myself. After I blew up my 3rd tranny I Went e153.
BANNED!
post May 9, 2006 - 11:34 AM
QUOTE(burneeed @ May 9, 2006 - 9:50 AM) [snapback]431915[/snapback]
guy, we've all said it to you here before.
you blowing up 3 trannys is more than likely some other issue, or your driving thats causing it.
i beat the hell outta my 175+k old, stock tranny with 230+whp and 270+ftlbs, with no issues, as well as several other members who daily drive theyre swaped cars with no issues.
post May 9, 2006 - 11:50 AM
QUOTE(presure2 @ May 9, 2006 - 12:34 PM) [snapback]431949[/snapback]
i agree 110%
there is no way that with your mods (most stock with, with a topmount ic) that the tranny faild, 3 times in 2 years. there is some other problem going on with your setup or your driving style.
post May 9, 2006 - 12:44 PM
bufferdan
Joined Nov 9, '03
From Dayton, OH
Why pull the engine to replace the clutch or tranny? JEhh... You can drop the tranny and figure out whats wrong, fix it, put it back together in a day.
post May 9, 2006 - 1:00 PM
QUOTE(presure2 @ May 9, 2006 - 7:25 AM) [snapback]431892[/snapback]
yeah. 3in IC piping might be an upgrade on an mr2 with a HUGE turbo, but would be a horrible idea for a car with a fmic. the lag would make the car not fun to drive at all. i would do 2.25-2.50 max. you cant apply everything the mr2 guys do, to our cars.
post May 9, 2006 - 1:02 PM
With reading the MR2 boards, the S54 tranny thats on n/a MR2s is the same as the 3sge tranny. I think thats why it can take a beating because its over-rated for the 5sfe engine. Thats my hypothesis.
7 Pages V   1 2 3 > »
5 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: December 4th, 2024 - 10:30 AM
