7 Pages V  « < 5 6 7
> YES 3sgte with a 5s stock tranny., some thing is broken. woot.
post Sep 13, 2006 - 10:00 PM
Jdog1385
Joined Apr 14, '03
From Long Island, N.Y.
crazy, made my decision on a clutch easier. so what clutch are you going for now?
post Sep 13, 2006 - 10:17 PM
you can always try the stage 3. jeff and i have them in our swaps and love them.
post Sep 13, 2006 - 11:06 PM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(lagos @ Sep 13, 2006 - 10:17 PM) [snapback]479485[/snapback]
post Sep 14, 2006 - 11:20 AM
QUOTE(jgreening @ Sep 14, 2006 - 12:06 AM) [snapback]479527[/snapback]
i dont think that exists. ive seen people complain about almost every brand for one reason or another. but yeah, there is alwasy CM, ACT, etc... to try out.
post Sep 14, 2006 - 11:41 AM
bufferdan
Joined Nov 9, '03
From Dayton, OH
Im coming to the conclusion that SPEC clutchs are junk...i wish i woulda never put the spec stage 3 in my mr2. It has almost 12k miles on it now and its working great but seeing all these problems isnt very promising.
post Sep 14, 2006 - 12:06 PM
Kadett
Joined Mar 17, '05
From The Netherlands
I installed a fresh 3S-GE clutch with the swap. It doesn't have the bite at a dead still like a performance one but still it does everything smoothly so far.
Maybe in the future when needed I will get a Ogura or C-One clutch if I keep this tranny.
post Sep 14, 2006 - 12:13 PM
hitcachi
Joined Jun 19, '05
From Nebraska
QUOTE(lagos @ May 9, 2006 - 10:17 PM) [snapback]432222[/snapback]
the 3sge was also sold in the 4th gen celica. not saying thats what jeff has, just that it might be something to look into, also.
if the insides of the jdm s54 were any different, wouldnt they change the model number of the trans?
Art, did anyone ever look into this and see if it might be an option for LSD?
post Sep 14, 2006 - 12:31 PM
malecrod
Joined May 30, '05
From MN
Funny. I had a similar problem with mine. Think its that the same spec clutch Doc used on my swap. I came off a highway to a stop light and for the life of me, car would not go into any gear. I was smelling burning clutch and when I finally got it in gear with a massive BRUT force, it was chattering, reving high and smelling. I dropped it off at a repair shop. shop thinks it the clutch. I have only put about 3000miles or so on the clutch since the swap. Now trying to figure out what brand of clutch kit to go with that can be ordered from a local part store so car can be back on the road ASAP.
3sgteing.
..burns twice as bright, lasts half as long.
"The weight of the world is love. Under the burden of solitude, under the burden of dissatisfaction."
-Allen Ginsberg-
post Sep 16, 2006 - 11:01 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
QUOTE(Batman722 @ May 9, 2006 - 7:32 PM) [snapback]432190[/snapback]
QUOTE(brianforster @ May 9, 2006 - 10:28 PM) [snapback]432186[/snapback]
i wonder what the part number is for the 3sge celica tranny, maybe that would help us
st202 - 3sge
30300-2b560 until 96
30300-2b570 all years
30300-2b670 96+ LSD
US st204 - 5sfe
30300-2b580
help you much BrianForster ?
think the local dealer could order the FWD LSD tranny?should still be the same GT axles too correct?
post Sep 17, 2006 - 12:24 AM
cheeco
Joined Jun 15, '06
From NJ
Well looks like the same thing happened to me, came around a curve, shifted from 2nd to 3rd, gave about 1/2 throttle punch, felt somthing pop and reved to about 7k. spec st2 clutch is most certainly toast. i also started to notice a fairly loud rattle at idle when the pedal was released, thought maybe it was the TB, guess not. I personally installed the clutch and broke it in properly, never dumped the clutch, no powershifting. The fork, TB and input shaft were all well lubed. The flywheel was resurfaced by me and all the metal mating surfaces were cleaned. also i was extra careful to ensure no pressure was on the clutch hub when mating up the trans. i am 100% sure installation was not an issue. tommorow ill get a better look at it, check everything over, and drop the trans if everything looks ok.
post Sep 17, 2006 - 10:39 AM
malecrod
Joined May 30, '05
From MN
Well, I found out what the problem was... it was indeed the spec clutch. There was a metal piece(don't know its name) on the clutch disc that broke off lucky for me it did not destroy anything else. The metal piece is shaped like a little hook and seats between the two clutch disc surfaces. There are several of these hooks, one of them broke off.
3sgteing.
-Allen Ginsberg-
post Sep 20, 2006 - 2:37 AM
urbandork
Joined Jul 16, '04
From Los Angeles
man all this talk is making me look for other options then the spec stg 2 setup.
im inbetween a spec stg3 set up or just getting a stage 3 5s setup and using the 5s flywheel.
post Jan 17, 2007 - 8:57 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(malecrod @ Sep 17, 2006 - 10:39 AM) [snapback]480692[/snapback]
What did spec say about all this????
7 Pages V  « < 5 6 7
6 User(s) are reading this topic (6 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: December 4th, 2024 - 10:30 AM
