> E manage ECU, Instead of wiring harnesses.
post May 9, 2006 - 1:27 PM
sugarfree
Joined Dec 21, '05
From dallas
My situation is i have a beams motor, that i need to get wired using my stock GT harness. Instead of getting my harnesses wired, can i just go with a e manage ECU and use the stock beams harness? Also, is something like a greddy e manage ECU universal?
Whopps, sorry if this is a repost.
This post has been edited by sugarfree: May 9, 2006 - 1:29 PM
post May 9, 2006 - 1:30 PM
a greddy emanage is a piggy back . you cant just use that to run your motor.
you need a stand alone ecu for what your planing to do . hydra nemesis or aem make 2 popular ones. even then, you still need to rewire a lot of stuff.
This post has been edited by lagos: May 9, 2006 - 1:31 PM
post May 9, 2006 - 1:35 PM
celicarus
Joined Jul 5, '05
From Arlington, TX
dude - didn't know u have a beams - man u gotta make time for me to come and see -- i'm off on fridays and saturdays - give me a call 4698550304
i am planning on using the emanage ultimate also -- on the 3s -- yep its a piggy back -- for a daily driver the emanage it more than enough --
post May 9, 2006 - 1:39 PM
sugarfree
Joined Dec 21, '05
From dallas
Thanks lagos for the quick reply!
Celiarus, yea i thought sun would of told you, i will call you when i have time.
post May 9, 2006 - 1:50 PM
QUOTE(celicarus @ May 9, 2006 - 2:35 PM) [snapback]431989[/snapback]
you dont need an emanage on a 3s. the 3sge or 3sTe are facotry motors and should run off their stock ecu's.
the only time you might want to use something like an emange, is if you upgrade the turbo and the injectors, and want to get some type of piggback to help you retune the car for the new fuel and air thats going in .
post May 9, 2006 - 2:28 PM
celicarus
Joined Jul 5, '05
From Arlington, TX
QUOTE(lagos @ May 9, 2006 - 1:50 PM) [snapback]431997[/snapback]
exactamundo - i am playing with my options at the moment and plan on using a bigger turbo - would like to make more than 275+ HP
This post has been edited by celicarus: May 9, 2006 - 2:30 PM
Lo-Fi Version Time is now: February 20th, 2025 - 5:33 AM
