Radiator |
Radiator |
May 11, 2006 - 2:07 PM |
Enthusiast Joined Jun 21, '05 From New york Currently Offline Reputation: 1 (100%) |
Which radiator should i use...the 5sfe one or my 3sgte one? Cuz they must not have the same efficiency, so i was just wondering.
bigal -------------------- 1994 celica GT.....3sgte in a month! all helpers are welcome!!! i live in Plattsburgh, NY.
May 11, 2006 - 2:11 PM |
for what? a swap?
you have to use the 5sfe radiator. -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 11, 2006 - 2:14 PM |
Yeah for my 3sgte swap into my 94 celica GT.....
Bigal -------------------- 1994 celica GT.....3sgte in a month! all helpers are welcome!!! i live in Plattsburgh, NY.
May 11, 2006 - 2:29 PM |
Enthusiast Joined Nov 3, '05 From Chicago Suburbs Currently Offline Reputation: 1 (100%) |
Would running the car hard in hot weather on 5sfe rad cause the ecu to limit boost ? I would suspect that if the water temps shoot well above 200 degrees (caused by poor efficency of 5s rad) there must be some fail-safe procedure because I experience something like that on my car when its hot out and i cant go over 10 psi untill it cools down a bit.
-------------------- QUOTE(tufy @ Jul 19, 2006 - 7:40 AM) [snapback]458074[/snapback] i dont drive fast, i just fly low |
May 11, 2006 - 4:10 PM |
why do you think the 5s radiator is efficently "poor" ?
if you really want the answer, pull out both radiators and compare them. -------------------- |
May 11, 2006 - 8:02 PM |
Enthusiast Joined Dec 2, '02 From Portland, Oregon Currently Offline Reputation: 0 (0%) |
The 5th gen celica uses the same radiator for the 5s and the 3s... it is more than enough for a stock 3s.
May 11, 2006 - 8:15 PM |
I did look at both radiators but i didnt tear it is hard to tell which is more efficient, they are both in good shape, i just didnt know with mounting and stuff which one to use.
Bigal PS But thanks for the advice! -------------------- 1994 celica GT.....3sgte in a month! all helpers are welcome!!! i live in Plattsburgh, NY.
May 11, 2006 - 9:10 PM |
I think the answer to this depends on your intercooler. My FMIC did not allow enough cold air to pass through so I had overheating problems with the stock intercooler and had to go to a double core. Many people have no problems with the stock unit though so you should try that first.
May 11, 2006 - 9:31 PM |
Enthusiast Joined Jun 4, '04 From Northern New Jersey Currently Offline Reputation: 2 (100%) |
heck im still on my ST radiator and have had no problem with it...maybe i'll pick up a GT or a 205 one...hmmm
bboy -------------------- ..(formerly daily driven) 3S-GTE powered celica currently set @ 12psi.. |
May 11, 2006 - 10:10 PM |
QUOTE(Batman722 @ May 11, 2006 - 5:10 PM) [snapback]432958[/snapback] why do you think the 5s radiator is efficently "poor" ? ?? -------------------- |
May 12, 2006 - 12:21 AM |
QUOTE(Batman722 @ May 11, 2006 - 5:10 PM) [snapback]432958[/snapback] why do you think the 5s radiator is efficently "poor" ? if you really want the answer, pull out both radiators and compare them. I just assumed that, either because it is not full aluminum, designed for ecno motor that does not require superior cooling? I think im wrong and Jay is right about the intercooler blocking the flow... Would you say that 5s rad is plenty good for slightly modded 3s ? is the st205 rad the same? just curious -------------------- QUOTE(tufy @ Jul 19, 2006 - 7:40 AM) [snapback]458074[/snapback] i dont drive fast, i just fly low |
May 12, 2006 - 2:51 PM |
Enthusiast Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
I'm using the st radiator too and have had no problems with overheating. My temp gauge stays right in the middle all day long.
May 12, 2006 - 10:25 PM |
Thanks for all the help! if the ST radiator works then i am sure the GT Radiator will work fine!
Lo-Fi Version | Time is now: November 23rd, 2024 - 3:28 AM |
