Enthusiast Joined May 10, '06 From tampa fl Currently Offline Reputation: 0 (0%) ![]() |
i was told its a dohc but the motor in mycar is sohc
![]() Enthusiast ![]() ![]() ![]() Joined May 24, '03 From Milton, Delaware Currently Offline Reputation: 0 (0%) ![]() |
7afe is a DOHC, with a slave cam design I believe.
-FAQ -------------------- AIM : FAQdaWorld
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 29, '02 From Franklin/Nashville, TN Currently Offline Reputation: 16 (100%) ![]() |
QUOTE(FAQdaWorld @ May 12, 2006 - 9:44 AM) [snapback]433233[/snapback] 7afe is a DOHC, with a slave cam design I believe. -FAQ correct. it isn't a true dual over head cam, but there are 2 cams. only one pulley though, that's what is meant by "slave cam design". -John- BTW: general (very general) rule of thumb: if the spark plugs are in the center of the head, it will be a DOHC motor, where as if they are offset to the front or back of the head, it is a SOHC. Again, very generalized, and mostly in the 4cyl family, is what i'm speaking of. -------------------- |
Lo-Fi Version | Time is now: February 20th, 2025 - 4:40 AM |
