Enthusiast ![]() Joined Nov 28, '05 From Connecticut Currently Offline Reputation: 0 (0%) ![]() |
I have a celica st and I was wondering if you use an altrac transmission, will it bolt up to the gt mounts. Also, if I were to do the swap, would I really have to get gt axles in the front?
you couldn't use the all-trac tranny unless you are planning on an all wheel drive conversion
![]() the most common and safest bet is to use a GT tranny with GT axles. Since you have an ST, you would need to use GT motor mounts/brackets with the tranny. -------------------- |
Lo-Fi Version | Time is now: February 17th, 2025 - 4:46 AM |
