Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) ![]() |
![]() Enthusiast Joined May 2, '03 From Sydney, Australia Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(chacha @ May 13, 2006 - 2:07 PM) [snapback]433631[/snapback] ![]() its in the how to articles mate. try http://www.6gc.net/index.php?action=howto&itu=88 |
Thanks bro, we need to post this type of help in the sticky in the "Engine" category...i will go try it now!
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 19, '05 From Nebraska Currently Offline Reputation: 4 (100%) ![]() |
all you have to do it take a paper clip and connect TE1 and E1 and then count the blinks.
-------------------- Teh Celica sleeps for Winter '06. Suspension overhaul begins........
hahaha...yeah...i got it...it is weird though...after testing it...it turned out to be the EGR system, but once i have identified it, i pull off the tubes and snugged it back in and the light is now gone...but b4 that, it would turn on and turn off...Ill have to wait and see untill torrow when i drive it to see if it will pop up again or not...i hope not...replacing the EGR is expensive...coughing out $150 is pretty rough, gas is already a BIG probelm!
ok, i thought i had my problems solved, but it is still popping out that same code error 71 : EGR system....is there something else i can do to test if i can fix it without getting a new EGR modulator or vacum?? what did you do if you had this same problem? any info is much appreciated!!
Lo-Fi Version | Time is now: February 25th, 2025 - 6:55 PM |
