Enthusiast ![]() ![]() ![]() Joined Aug 14, '05 From St. Paul, MN(USA) Currently Offline Reputation: 8 (100%) ![]() |
would the 185 mounts and 185 shift cables work w/ a 3sgte swap into a 94 GT??
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) ![]() |
you are going to need GT mounts and GT shifter cables, all of this information is located in defgephs howto
http://www.6gc.net/forums/index.php?showtopic=28825 |
![]() Enthusiast ![]() ![]() ![]() Joined May 5, '05 From New-Brunswick Canada Currently Offline Reputation: 3 (100%) ![]() |
to sum things up
it depends on weither you're going to use a E153 5spd (same as ST185 transmission but in FWD). if you decided to use the stock GT tranny, no, you don't need the mounts and shift links if you do put the E153, you're going to need the firewall side mount, driver side mount (RHD), shifter cables, mr2 turbo inner axles (lsd tranny need inner lsd axles) and st185 outter -------------------- ----------------------6GC's FIRST V6----------------------
![]() JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy |
Lo-Fi Version | Time is now: February 22nd, 2025 - 3:23 AM |
