cold start time injector switch, first start of the morning is a rough one |
May 27, 2006 - 9:36 AM |
http://mr2.noegruts.com/engine/engine02s.jpg
thats a pic of the time switch location. its has a brown harness plug connected to it, and is right behind the coolant temp sensor (green harness plug). just unscrew it and screw a new one on. do this when the car is cold, or youll get burned with coolant. i just fired mine up again for the 3rd cold morning in a row. starts perfectly on one crank and the problem is totally fixed for me ! 5bucks at a junk yard, well spent! -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 27, 2006 - 2:57 PM |
Enthusiast Joined Aug 17, '04 From California Currently Offline Reputation: 20 (100%) |
QUOTE(lagos @ May 27, 2006 - 2:36 PM) [snapback]438381[/snapback] http://mr2.noegruts.com/engine/engine02s.jpg thats a pic of the time switch location. its has a brown harness plug connected to it, and is right behind the coolant temp sensor (green harness plug). just unscrew it and screw a new one on. do this when the car is cold, or youll get burned with coolant. i just fired mine up again for the 3rd cold morning in a row. starts perfectly on one crank and the problem is totally fixed for me ! 5bucks at a junk yard, well spent! the link isnt working but i have an idea where to find it. Thanks again. |
May 31, 2006 - 12:01 AM |
Enthusiast Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) |
Doing this really helped me out with the help of Jeff's pic and guide...if you are having some trouble starting up early in the morning, where the car bogs on and off...
1. Remove the whole Throttle body piece from intake manifold 2. try removing the IAc attached to the throttle body, unscrew the four small screws that holds IAC in place.. 3. Clean the IAC with some B-12 Carb formula with a Metal small brush to brush off all the black gunk stuck in the small holes in the IAC...since you are doing this, might as well clean your throttle body and intake manifold to your best ability with some of the Chemical (B-12 Carb formula) 4. Let it dry for 10 minutes and attached everything back together... This should solve problem...better air flow and suction...stronger the car is at recieving a better idling at higher RPM... *note: if you are unexperience and don't know much and scared to do it (like me)...it will take a while...more than 4 hours of frustration and anger...because of bolts that won't come lose...if that is the case... use a VICE-GRIP TOOL to get the small bolts/nuts out and replace it with M5-.8 nuts/bolts...preferrably the 5mm x 16 should do the trick...found at home depot...$0.75 On the other hand, if you know what to do, less than 15 minutes for everything to work out fine **I just took my whole throttle piece to a shell mechanic store to have them help me turn the stubborn nuts/bolts off from my IAC connected to the Throttle Body...using their VICE-GRIP TOOL....didn't charge...they just twist it and turned it out for me... I haven't had the chance to ride it and test it in the mornings...but i will update. REMEMBER, this is just one way to help, if this doesn't help out at all....might be your small THERMOSTATS that's messed up, or some other parts....this took me a while to find the solutions to solve this darn problem...hope it helps you guys...if in doubt, aim me @ chasquare... This post has been edited by chacha: May 31, 2006 - 12:07 AM |
Jan 7, 2007 - 5:42 PM |
Enthusiast Joined Jan 13, '06 From UnderTheGround403 Currently Offline Reputation: 2 (100%) |
Sorry to bring this thread back, but are the sensors between the 5sfe and the 3's interchangeable, even though they have different resistance numbers?
Are the coolant sensor also interchangeable as well? Can someone tell me what the sensor on the back of the neck (on the 3's) that has only one wire going to it is? Is it the sensor for the dummy light? |
Jan 8, 2007 - 12:15 AM |
Enthusiast Joined Jun 19, '06 From Portland, OR Currently Offline Reputation: 1 (100%) |
I find it interesting how you guys have cold start issues.. I removed my cold start system and have no issues .. it fires right up.. however from time to time I'll have hot re-start issues... requiring more cranking than usual.. a little throttle play helps it..
-------------------- 87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
Jan 8, 2007 - 12:55 PM |
Alright I know this is a silly question but, how do you take the sensor out? I hot the harness plug out but dont know how to remove the sensor itself. Does just the plastic base unscrew or does the metal nut attached underneath the plastic base unscrew? If it is the metal nut, how do you get a wernch/socket in that tiny space?
Also what is that little metal "hook" that is right next to the sensors. It is bolted to the engine. It is in the middle/right half of the pic. Can I take this out? I find it hard to fit my fat hands into that small space with that "hook" thing there. |
Jan 8, 2007 - 1:13 PM |
QUOTE(Punisher @ Jan 8, 2007 - 12:15 AM) [snapback]516030[/snapback] I find it interesting how you guys have cold start issues.. I removed my cold start system and have no issues .. it fires right up.. however from time to time I'll have hot re-start issues... requiring more cranking than usual.. a little throttle play helps it.. if you have to crank your car more then once, under any temp condition, then thats because of the time switch. on my car, i would start fine in the winter, but have to crank it a few times in the spring. replacing the sensor fixed the problem. 6gsillyca..... unplug the harness plug. then use a wrench not a wrachet to unscrew that sensor by the metal base. do it when the car is cold, or you will burn yourself. This post has been edited by lagos: Jan 8, 2007 - 1:15 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 8, 2007 - 2:57 PM |
QUOTE(lagos @ Jan 8, 2007 - 1:13 PM) [snapback]516122[/snapback] QUOTE(Punisher @ Jan 8, 2007 - 12:15 AM) [snapback]516030[/snapback] I find it interesting how you guys have cold start issues.. I removed my cold start system and have no issues .. it fires right up.. however from time to time I'll have hot re-start issues... requiring more cranking than usual.. a little throttle play helps it.. if you have to crank your car more then once, under any temp condition, then thats because of the time switch. on my car, i would start fine in the winter, but have to crank it a few times in the spring. replacing the sensor fixed the problem. 6gsillyca..... unplug the harness plug. then use a wrench not a wrachet to unscrew that sensor by the metal base. do it when the car is cold, or you will burn yourself. But that time switch is for the cold start injector... which I don't have... -------------------- 87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
Jan 10, 2007 - 1:36 AM |
Thanks Art. I got the water temp sensor (green harness plug) and the cold start injector time switch (brown harness plug) out. How much coolant is supposed to leak out? After I took the cold start sensor out, almost a cup has leaked out already. Is that normal? Can you also update me on how your 4k resistor is working? Have you had any problems with the reduced resistance?
Does anyone have any input on the "hook" thing? You can see the bolt that is holding it to the engine in the bottom left of the pic. At first I thought it was a support for when you pull the engine, but it seems a bit too thin/flimsy for that. This post has been edited by 6gsillyca: Jan 10, 2007 - 1:43 AM |
Jan 10, 2007 - 1:44 AM |
Enthusiast Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
i believe when our 5sfe's came out toyota no longer used cold start injectors but just cold start fuel maps.
Jan 10, 2007 - 1:55 AM |
The bgb off mr2oc has a section for the 5sfe cold start injector/time switch.
I want to try switching out the CSITS between the 3's and the 5sfe and see if it makes any difference. |
Jan 10, 2007 - 2:07 AM |
QUOTE(6gsillyca @ Jan 10, 2007 - 1:36 AM) [snapback]516587[/snapback] Thanks Art. I got the water temp sensor (green harness plug) and the cold start injector time switch (brown harness plug) out. How much coolant is supposed to leak out? After I took the cold start sensor out, almost a cup has leaked out already. Is that normal? Can you also update me on how your 4k resistor is working? Have you had any problems with the reduced resistance? Does anyone have any input on the "hook" thing? You can see the bolt that is holding it to the engine in the bottom left of the pic. At first I thought it was a support for when you pull the engine, but it seems a bit too thin/flimsy for that. 4k resistor? you mean the difference in resistance ratings of the two sensors? it works ok. car starts right up on first crank, ever time. but i can kind of tell that its not 110% what you would get from the proper sensor. but thats just me being picky. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 10, 2007 - 2:14 AM |
if it starts up every time, first try, then what is not 110% about it? How would the "proper" sensor be different?
Where does it say what resistance it is? Does the 89462-20020 plug have the resistance labeled on it? |
Jan 10, 2007 - 8:37 AM |
QUOTE(6gsillyca @ Jan 10, 2007 - 2:14 AM) [snapback]516598[/snapback] if it starts up every time, first try, then what is not 110% about it? How would the "proper" sensor be different? Where does it say what resistance it is? Does the 89462-20020 plug have the resistance labeled on it? its kind of hard to explain it. its something you know by feel of how the car starts up. if you look at the sensor itself, it will say the resistance right on it. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 10, 2007 - 5:29 PM |
QUOTE(6gsillyca @ Jan 10, 2007 - 1:55 AM) [snapback]516589[/snapback] The bgb off mr2oc has a section for the 5sfe cold start injector/time switch. I want to try switching out the CSITS between the 3's and the 5sfe and see if it makes any difference. the mr2 used the equivlent of a 5th gen 5sfe, which does have the CSI. the 94+ 5sfe does not have a cold start injector. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Jan 11, 2007 - 12:56 AM |
Which sensors are these then (94 celica 5sfe)
BTW How much coolant is supposed to leak out? Overnight a TON came out. I have a huge puddle underneath my car now. I hope it was just because it was a little on the "full" side to begin with. This post has been edited by 6gsillyca: Jan 11, 2007 - 12:46 PM |
Jan 18, 2007 - 3:16 AM |
Sorry to bring it back again but, does anyone know if there is a different part number for the jdm mr2 and the usdm mr2? Also what the different numbers are for the various years.
I called the dealership up today and gave them the 89462-20020 and was told that was for a 90/91 mr2. He then continued to tell me that the part number for a 93 is 89462-20040, even though the part I pulled from my engine was a 20020. Any idea's? |
Jan 18, 2007 - 3:28 AM |
just get the same one as the motor had before.
my motor is a 90 and it originally had a 89462-20020 sensor. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 18, 2007 - 4:39 AM |
Normally I would, but my motor *should* be a 93, and those origionally should come with a 89462-20040 sensor.
I think it might have gotten switched out along the way somewhere, and thats whats giving me issues. |
Jan 24, 2007 - 3:11 PM |
QUOTE(6gsillyca @ Jan 18, 2007 - 3:39 AM) [snapback]518881[/snapback] Normally I would, but my motor *should* be a 93, and those origionally should come with a 89462-20040 sensor. I think it might have gotten switched out along the way somewhere, and thats whats giving me issues. The clip was sold as a 93 and I am positive that the intake manifold is a 93. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Lo-Fi Version | Time is now: November 30th, 2024 - 2:36 PM |
