![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 23, '05 From Kansas City Currently Offline Reputation: 0 (0%) ![]() |
So I've been thinking about running some Seafoam through my engine. A lot of guys in various clubs with me here have done the same and say it's amazing. My friend's Audi TT was having some valve chatter and such and he cleaned it with Seafoam and now it's PERFECT.
For those who don't know, Seafoam is an engine cleaner/carbon deposit remover. Supposed to put 1/3 in your gas tank, 1/3 in your oil, and 1/3 through a vacuum line like the brake booster then run the car for about 15 minutes (it'll smoke and everything a LOT) then change your oil and boom your done. What I've heard though is on higher mileage engines it's bad to use something like this because the carbon deposits etc that it cleans out could be blocking leaks, and when they're gone you could spring some engine leaks. Feedback anyone? I need stuff to do this week lol -------------------- 1999 Celica GT
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) ![]() |
im kinda iffy on that idea because our vehicles are not new...some of the chemicals out there for that exact purpose can eat or destroy the rubber gaskets or other lining materials that enables oil or other fluid in the car to leak...newer cars tends to have an advantage because most of the stuff the engine components have are still new and can endure the chemical stuff...ours too old and god knows how many things are engine components needs to be replace, that's why there are different chemicals with the same purposes for different high or low millage cars....BUT THEN AGAIN...THIS IS WHAT I HAVE BEEN TOLD...DON'T TAKE MY WORD FOR IT...
![]() Enthusiast ![]() ![]() Joined Dec 3, '04 From torrance, ca Currently Offline Reputation: 0 (0%) ![]() |
seafoam is good stuff lol looked like my car was on fire when i started it
QUOTE(hellsyphon @ May 15, 2006 - 1:22 AM) [snapback]434132[/snapback] seafoam is good stuff lol looked like my car was on fire when i started it ![]() yeah you're supposed to change your oil the minute you're done with it because it thins out your oil a lot I have 135,000 miles and I'm just afraid I'll start leaking really bad haha -------------------- 1999 Celica GT
lol well one way or another your gonna have to end up fixing leaks so might as well have a clean engine to boot
![]() *it wasnt a big leak just a small one if that makes you feel better lol This post has been edited by hellsyphon: May 15, 2006 - 1:44 AM |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 19, '05 From Nebraska Currently Offline Reputation: 4 (100%) ![]() |
I use the stuff quite a bit. It works wonders. No problems here, just use it properly.
-------------------- Teh Celica sleeps for Winter '06. Suspension overhaul begins........
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '04 From Illinois Currently Offline Reputation: 0 (0%) ![]() |
If I were to use it, I probably would not put it in my oil. Here is a pretty good thread to look at:
Seafoam bad story thread -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
QUOTE(jgreening @ May 15, 2006 - 2:16 PM) [snapback]434298[/snapback] If I were to use it, I probably would not put it in my oil. Here is a pretty good thread to look at: Seafoam bad story thread have to login to see that link. -------------------- |
QUOTE(Bitter @ May 15, 2006 - 4:05 PM) [snapback]434322[/snapback] QUOTE(jgreening @ May 15, 2006 - 2:16 PM) [snapback]434298[/snapback] If I were to use it, I probably would not put it in my oil. Here is a pretty good thread to look at: Seafoam bad story thread have to login to see that link. correct. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Lo-Fi Version | Time is now: February 22nd, 2025 - 1:07 AM |
