> Wobbling while steering
post Jun 9, 2003 - 2:57 AM
khanster
Joined Dec 16, '02
From canada
hey i got a 97 celica gts and my steering starts to like go loose and wobble when i'm goint about 100km/h or over. anything underneath 80km/h the steering is nice and stiff but i dont' know why it wobbles at such high speeds.
i just got my wheels balanced but that didn't seem to help the problem.
post Jun 15, 2003 - 12:02 PM
exxtractor
Joined Mar 31, '03
From BC
I would have guessed alignment or wheel balance. However, you might want to take it to a Toyota Dealer and ask them to take it i the highway over 100 km/h and most oftem the mechanic will know the cause, and if they charge you for he work and the problem exisits, usually they'll will try and fix it without charging you again since they didn't correct the problem the first time.
post Jun 15, 2003 - 2:25 PM
95STCelica
Joined Oct 12, '02
From New Jersey
feel the top of your front tires, you might be able to tell if the belts are worn, that is what happened to mine, got new tires and the shaking of the wheel went away. let me know how it works out wink.gif
post Jun 15, 2003 - 5:03 PM
HyperDeathKill
Joined Apr 20, '03
From Chicago
wait, what belts? Sorry I don't know much.
post Jun 15, 2003 - 11:50 PM
turbine
Joined Mar 12, '03
From Minnesota
Hi. Check the tires for air pressure and balance. I had a similar problem with my old 5th gen celi and that solved it.
Lo-Fi Version Time is now: November 25th, 2024 - 1:28 AM
