> removing 3sgte exhaust manifold
post May 15, 2006 - 8:53 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
since i am not home today i ahd chucky try and remove my exhaust manifold for me so i can trade it for a stock one, he said however that a few bolts were unreachable and a couple were on so much that it turned the stud too
do these studs come out of the block?
if not why are they turning?
anyone have any tips to help us get this off?
post May 15, 2006 - 8:55 PM
bojangles_8686
Joined Nov 12, '02
From Baltimore, MD
Yeah the two top and middle most studs spin when I try to take the nut off. I was able to use vice grips to get one of the nuts a little loose but the threads got messed up so I stopped.
post May 16, 2006 - 12:03 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
Just remove the entire stud. You can then take them to a vice a carefully remove the nut. Then thread the stud back into the block after a quick cleaning. Make sure you thread the proper side to the block.
I will return one day.
post May 16, 2006 - 12:20 AM
brianforster
Joined Mar 3, '04
From Hollywood, MD
ok, chucky wasnt sure if the entire stud could be removed
post May 16, 2006 - 9:05 AM
bojangles_8686
Joined Nov 12, '02
From Baltimore, MD
I tried taking them out but they didnt seem to want to so yeah I wasnt sure, do I have to screw them out or can they just be pulled?
post May 16, 2006 - 9:38 AM
QUOTE(bojangles_8686 @ May 16, 2006 - 10:05 AM) [snapback]434562[/snapback]
they are threaded in.
Lo-Fi Version Time is now: November 30th, 2024 - 2:35 PM
