4 Pages V  « < 2 3 4
> My Emanage Ultimate experience, 5sfte + emanage ultimate = ??? lets find out!
post Jul 6, 2008 - 3:52 AM
NuclearHappineS
Joined Oct 17, '04
From St Louis, MO
Sup man,
This is off topic (for my benz) ...
Can I do ALL of the following with the e-manage:
Use one analog in/out to clamp my map sensor voltage to raise my stock boost control from 6 to 11psi
Use the airflow correction map to clamp it at 163 g/s (190hp) to prevent the ECU from limping when it sees more than 190hp worth of air
Use the Injector correction to add the needed fuel that the ECU isn't adding (because i had clamped the MAS voltage to prevent it from freaking out).
Using TWO additional analog in/out signals to modify my TPS signal and my backup TPS signal (drive by wire)... which will reduce throttle lag
Use one switched digital output so that I can take control over my boost bleed air injection system so that I can hold all my boost in when i go WOT rather than have it bled into the cat to keep emissions down.
Do all of this without touching my ignition setup (very complex COP) and keeping timing / ignition control with the ECU
Do all this while taking the Emanage RPM input from any of my 4 coils (as there is no dizzy or rpm pulse that i could tap into)
Do all of this while using my MAP as my TPS input (so the E-manage knows when the car is shifting (boost drops to 0 and then builds again) even when i'm 100% floored ) (automatic transmission) (possibly using the manual min/max settings for the TPS)
How does the additional injection pulse width feature work, do you CUT the injector wires or do you just tap into them like the EM-Blue ?
If you cut them totally ? do you think it will trigger a CEL on OBD-2 ?
Thanks man...
2005 MB C200 Kompressor- K&N, Apexi WS2 Catback, DIY Voltage stabilizer, Intrax Springs, H&R RR swaybar, VDO Boost Gauge @ 6psi, Greddy L7 plugs, +0 Rear tires
To Do: E-manage Ultimate tuned up to 12psi
post Jul 6, 2008 - 11:24 AM
QUOTE (NuclearHappineS @ Jul 6, 2008 - 4:52 AM) *
Sup man,
Thanks man...
ok lets see.
yes for sure for the first 3. the next 3 i "think" it can do, you'd have to research the manuals yourself for those.
yes to not touching the IG side.
it itercepts the injector outputs. ( cut wires) i have read of a few issues with triggering the CEL, but there has been updates and such to help correct the problems people were having early on.
'specially with the benz nuke, i would think the redundant systems would catch on, but who knows unless you try!
post Jul 6, 2008 - 2:21 PM
NuclearHappineS
Joined Oct 17, '04
From St Louis, MO
So I did some reading ...
** Use one analog in/out to clamp my map sensor voltage to raise my stock boost control from 6 to 11psi
+ YES
** Use the airflow correction map to clamp it at 163 g/s (190hp) to prevent the ECU from limping when it sees more than 190hp worth of air
+ YES or Just use the Boost Cut Limiter setting to clamp the MAS Voltage
** Use the Injector correction to add the needed fuel that the ECU isn't adding (because i had clamped the MAS voltage to prevent it from freaking out).
+ YES
** Using TWO additional analog in/out signals to modify my TPS signal and my backup TPS signal (drive by wire)... which will reduce throttle lag
+ NO (It only has 2 analog in/outs , one is used for MAS and one is used for MAP so i'm out of inputs)
** Use one switched digital output so that I can take control over my boost bleed air injection system so that I can hold all my boost in when i go WOT rather than have it bled into the cat to keep emissions down.
+ YES - I can either do this through the Vtec interface and the Auxilliary output setting map or using the NVCS/Relay channel depending on weather I need to supply +12v or 0v to the solenoid.
+ YES
+ YES requires jumper setting and choosing the right rpm type
+Yes , just wire the MAP to both analog input 2 and the TPS input
+You cut them totally... and rewire hte emanage to your injectors,
Some cars do throw a CEL (including 98+ 3000GT's) and greddy has created an extra wiring pack to simulate injectors ... I'm attaching it for info ... actually i can't attach on here ?
Anyway, you can buy it from greddy for 50 bux... it solves the CEL problem ...
I'm gonna look around, maybe there's another device that has more analog I/O's where i can do it all ...
post Jul 9, 2008 - 1:28 AM
xxFROZENxx
Joined Nov 13, '06
From AUSTRALIA(MELB)
nice manny.. what kind of harness kit are you using and what car is it for? do you have a full step to step installation guide for that ultimate wire to the 5sfe ecu? im all the way over in Australia and i plan to buy the greddy ultimate to tune my 5sfte to. if you can supply me with one it will be great. smile.gif
post Jul 9, 2008 - 10:33 AM
NuclearHappineS
Joined Oct 17, '04
From St Louis, MO
only harness maker i know of...
http://www.boomslang.us/ultimate.htm
but pretty much you have to wire it yourself ... it's not hard especially if you have the ECU pin outs for your car.. it may take you only 2-3 hours to do the whole thing...
post Jul 10, 2008 - 4:29 PM
WALKER
Joined Mar 29, '06
From Regina, SK, Canada
QUOTE (NuclearHappineS @ Jul 9, 2008 - 9:33 AM) *
Don't really think the Boomslang would work since they don't have our cars listed. Possibly get a custom harness made up from them, but probably easiest to just wire it yourself.
post Jul 10, 2008 - 8:46 PM
supershannon77
Joined Jan 18, '07
From Bergen county NJ
could u use the mr2 one?
facebook WRC st205
post Jul 17, 2008 - 1:41 AM
xxFROZENxx
Joined Nov 13, '06
was the hardness kit for a 3sge or is it a universal one?
post Jul 23, 2008 - 2:08 AM
xxFROZENxx
Joined Nov 13, '06
bump
post Jul 23, 2008 - 2:09 AM
universal.
4 Pages V  « < 2 3 4
Lo-Fi Version Time is now: November 24th, 2024 - 7:49 PM
