> Vibration when slowing at high speeds
post Jun 9, 2003 - 11:15 AM
Blackdolla
Joined May 23, '03
From New Orleans
When I slow down from a high speed (like coming of the interstate) my steering will starts to rattle and shake. I don't think the whole car shakes though. It seems to be just the steering wheel.
What could be the problem?
post Jun 9, 2003 - 5:22 PM
hi_rider
Joined Mar 17, '03
From Quebec
if the steering wheel shakes...check your tie-rod ends (most) or tab bushings (less) or ball joint...
even there...i don't see why it would shake with a loose tie-rod....at least, check if you wheels are round !!! (bent rim). yeah...it could be many things.....check everything.....wouhouuuu, what a hint i,m giving you......hahahahaha.. It doesn't need a huge loose to rattle..barely visible...
post Jun 9, 2003 - 6:21 PM
94TRDCeli
Joined Jan 29, '03
From Texas
sometimes cars just do that if you brake too hard froma high speed
post Jun 12, 2003 - 1:09 AM
62ndXAssAssin
Joined May 28, '03
yeah it could be that...or there's alot of run out on ur rotors
post Jun 12, 2003 - 4:00 PM
Blackdolla
Joined May 23, '03
From New Orleans
what do you mean by run out on the rotors?
post Jun 12, 2003 - 4:55 PM
62ndXAssAssin
Joined May 28, '03
hmmm...leemme see how to define it ...cus it's easier for me to me show u but since were online i cant...ok ur lookin at the rotor like in a fron view while it's spinning...run out is the lateral movement from side to side...so if u see urrotor and it has lateral play das run out...n das not good.
Lo-Fi Version Time is now: November 29th, 2024 - 3:59 AM
