> 94 head into a 98, will it work?
post May 17, 2006 - 7:27 PM
fastcelica20
Joined Apr 4, '06
From Minnesota
okay my car is weird. my car is a 95 but has a 99 motor/tranny. will it work if i put in a 94 head into the 98? will i lose power? torque? btw, mine is a 2.2 liter GT. ty
post May 17, 2006 - 7:31 PM
Clipsetuner
Joined Sep 12, '03
From Portland , Oregon , United States
I dont think you will lose or gain anypower.
EGR and emissions stuff you gotta change but thats about it.
DTE
I am a thief.
do not buy anything from me.
post May 17, 2006 - 7:34 PM
fastcelica20
Joined Apr 4, '06
From Minnesota
QUOTE(Clipsetuner @ May 17, 2006 - 7:31 PM) [snapback]435063[/snapback]
DTE
uh, im only changing the head not the whole engine. my head has a crazy click/knock and the mechanic told me to change the head. he said it is knocking because maybe timing belt. it hasn't been changed for a long time. he also said it's my lifters? i dont know that's why i need to change my head. i dont want anything else to worry about. i just want a nice quiet ride. without the knock knock knock are you there sound.
post May 18, 2006 - 8:03 PM
fastcelica20
Joined Apr 4, '06
From Minnesota
anyone know? im changing my head this weekend so i need to know asap. i dont want to make a mistake. also the head is 100 bucks. does that sound like a good deal?
post May 18, 2006 - 8:27 PM
fastcelica20
Joined Apr 4, '06
From Minnesota
also i just remembered about the obd1 obd2 stuff. what do i need to change? things that need to go out? things needed to be added? things needed to be replaced (ex: distributor, etc). thanks. this is urgent i need help! where are all the knowledgable guys at? tongue.gif
post May 18, 2006 - 9:42 PM
Starcraftjunkie
Joined Nov 21, '05
From Wpg, MB. Canada
soo.. is it the head or the timing belt... because they're very different things. tongue.gif When was the last time the timing belt was changed?
If you're doing the timing belt, you should also consider doing the waterpump, tensioner, idle pulley, the associated seals (crank/cam/etc) since they're all in the same area and it'll save on the overall labour. Do a search on the topics here for more info.
post May 18, 2006 - 9:59 PM
team_omega
Joined Aug 14, '05
From St. Paul, MN(USA)
if there is a knocking from a head then its your valves knocking...it might be going bad(bent valve, loose valve, etc)
post May 18, 2006 - 10:04 PM
fastcelica20
Joined Apr 4, '06
From Minnesota
QUOTE(team_omega @ May 18, 2006 - 9:59 PM) [snapback]435552[/snapback]
that's what i was sayin! thank you!
hey team omega, u know where that eastside import shop is right? that hmong owned auto place? i took it there and the guy said i needed a new head so it can't be my timing. i took it to young auto on maryland st and the owner said i needed a new engine. he also said it could be my timing belt. i mean if it was my timing, my engine would not be running this long (9 months).
post May 19, 2006 - 8:29 AM
pure_dx
Joined Dec 28, '05
From USA
^yeah, i know where young auto is, my uncle owns the place, try changing the head if you're on a budget, otherwise if you have a lil more $, swap in another 5sfe, and if you have tons of $$$$$$$$$$$$$$$$$, do a 3sgte swap yo!!!!!!
post May 19, 2006 - 9:28 AM
recneps
Joined Jul 7, '04
From charlotte N.C.
waterjackets dont line up.
you should do a search.
Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph.
Next: maybe an elise
post May 19, 2006 - 10:09 AM
fastcelica20
Joined Apr 4, '06
From Minnesota
QUOTE(recneps @ May 19, 2006 - 9:28 AM) [snapback]435678[/snapback]
i did search. otherwise if i searched i wouldn't be here. i found an old thread on pressure's 94 to 98 swap. but that didn't help me one bit.
pure dx, tell your uncle to give me a discount man!
Lo-Fi Version Time is now: November 23rd, 2024 - 4:50 PM
