![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 20, '06 From Florida Currently Offline Reputation: 44 (100%) ![]() |
Just curious to where the i need to install the mr2 fuel pump i got with my engine for the swap. Is it an inline pump? or does it go in the tank somewhere.. im new to fuel pumps and haven't taken the time to poke around too much under the car yet. Or should i just toss it and buy the walborro? i really just need to get the thing running since i only have about a month before the car has to be running and be reliable. I could always upgrade to the walborro after.
Thanks This post has been edited by jcbass7: May 18, 2006 - 6:58 PM |
Yeah its in the tank. Under the back seat theres a metal plate you have to uncover and disconnect the lines and take it out and swap it.
QUOTE(Supersprynt @ May 18, 2006 - 11:53 AM) [snapback]435284[/snapback] Yeah its in the tank. Under the back seat theres a metal plate you have to uncover and disconnect the lines and take it out and swap it. sweeeeet, ok thats this afternoons project then many thanks |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '04 From Illinois Currently Offline Reputation: 0 (0%) ![]() |
If you plan to upgrade the turbo, I would ditch the stock mr2t fuel pump and go with a 255 lph pump - either the walbro or the Supra pump.
Enthusiast ![]() ![]() ![]() Joined Dec 18, '05 From BANNED Currently Offline Reputation: 0 (0%) ![]() |
anyone ever replace a fpump in a mr2.. its a pain. In our cars its real easy.
-------------------- BANNED!
i have the ct26 turbo, and im assuming thats a stock turbo on the 3sgte right? i have no plans for the early future to change the turbo. when the time comes though ill throw the walboro or the supra pump in..
here is the new dilemma... the stock pump has 5 wires leaving it and the mr2 pump has 4. is there a wire i dont need to connect?
QUOTE(jcbass7 @ May 18, 2006 - 6:38 PM) [snapback]435433[/snapback] here is the new dilemma... the stock pump has 5 wires leaving it and the mr2 pump has 4. is there a wire i dont need to connect? when you pull the actual PUMP outta the tank, youll notice there is only 2 wires. -------------------- Former Team 5SFTE pro member ;)
ahh ok even better. I can't get the pump out yet because the part that is threded on the fuel line is rusted shut.. i let some pb blaster soak on it over night ill try again tonight
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) ![]() |
Go buy a set of flare wrenches. Those lines are very rusty and very tight. A nomal box wrench will most likely round off the nuts.
-------------------- ![]() I will return one day. |
^ Yeah and when you decide not to and then use vice-grips you'll make it worse.
QUOTE(Supersprynt @ May 19, 2006 - 2:04 PM) [snapback]435741[/snapback] ^ Yeah and when you decide not to and then use vice-grips you'll make it worse. BWAHAHAH how true is that !!!!!?!?!?!? good stuff erik. ![]() -------------------- Former Team 5SFTE pro member ;)
i guess its a good thing i couldnt find the vice grips yesterday when i was looking
Lo-Fi Version | Time is now: February 24th, 2025 - 3:09 AM |
