![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 17, '04 From California Currently Offline Reputation: 20 (100%) ![]() |
Hello everyone, I am getting ready to get a boost controller and put my 3sgte at 13psi and wanted to make sure i dont miss anything and hutrt the motor.
I will install a FMIC and a turbo xs boost controller. i have the stock ct26 turbo on the 2nd gen 3s. Aside from a better fuel pump what else will i need to do? Thanks for the help ahead of time This post has been edited by eggman40: May 18, 2006 - 3:44 PM |
the stock turbo for that car is a ct26 not a ct20.
get your fmic and a walbro or supra fuel pump in the tank. other then that, turn it up and enjoy the new car. 13psi is where it all starts to come alive. -------------------- 15PSI - 30MPG - Megasquirt Tuned
youll also have to disable fuel cut. there are many ways to do that tho
QUOTE(lagos @ May 18, 2006 - 8:35 PM) [snapback]435374[/snapback] the stock turbo for that car is a ct26 not a ct20. get your fmic and a walbro or supra fuel pump in the tank. other then that, turn it up and enjoy the new car. 13psi is where it all starts to come alive. ![]() ![]() Fuel cut will this work or can i find it cheaper? |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) ![]() |
You can disable fuel cut by disconnecting the vacuum line to the Turbo Pressure Sensor and plugging it.
If you want to retain fuel cut you can just wire in a zener diode to the PIM input of your ECU or build this simple circuit to make it adjustable: http://toymr2.tripod.com/fcd.html EDIT: WHOA! just clicked the ebay link... DO NOT PAY $89 FOR THAT! This post has been edited by WannabeGT4: May 18, 2006 - 4:14 PM -------------------- ![]() Project ST204.5 99.88946% complete... |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 4, '04 From Northern New Jersey Currently Offline Reputation: 2 (100%) ![]() |
fuel cut defenders like the hks are highly overrated. i think the lowest boost u can set the hks one to is actually 17psi if im not mistaken. theres a great how-to over at mrcontrols.com on how to make ur own fuel cut defender. i made one for myself based on that site and its fully adjustable and works like a charm. or if ur not too familiar with electronics i can make 1 for yah
edit: the link wunnabegt4 posted is the how-to im talking about...its alot more adjustable than the hks bboy This post has been edited by BBoYRuGGeD: May 18, 2006 - 5:33 PM -------------------- ![]() ..(formerly daily driven) 3S-GTE powered celica currently set @ 12psi.. |
QUOTE(WannabeGT4 @ May 18, 2006 - 8:54 PM) [snapback]435382[/snapback] You can disable fuel cut by disconnecting the vacuum line to the Turbo Pressure Sensor and plugging it. If you want to retain fuel cut you can just wire in a zener diode to the PIM input of your ECU or build this simple circuit to make it adjustable: http://toymr2.tripod.com/fcd.html EDIT: WHOA! just clicked the ebay link... DO NOT PAY $89 FOR THAT! Thank you, that helps a lot! the mr2 instructions look complicated. Ill get back to you guys on what i had to do. thanks again i appriciate it |
just unplug and cap the map sensor. thats what i did. free fuel cut!
i did build my own fcd based on that sites info, but never got around to installing it in my car. -------------------- 15PSI - 30MPG - Megasquirt Tuned
bboy.... can you take a pic of where you mounted your fcd and how it ended up looking?
QUOTE(lagos @ May 19, 2006 - 1:21 AM) [snapback]435508[/snapback] bboy.... can you take a pic of where you mounted your fcd and how it ended up looking? sure thing bboy -------------------- ![]() ..(formerly daily driven) 3S-GTE powered celica currently set @ 12psi.. |
![]() ![]() i used this ^ velcro to mount it. this things awesome if u wunna mount anything to a brick, metal, or plastic surface. its weather proof too and can hold heavy crap like my drill on my garage wall lol bboy -------------------- ![]() ..(formerly daily driven) 3S-GTE powered celica currently set @ 12psi.. |
all good stuff. i was wondering how i would mount mine. velcro seems like an easy fix to that problem.
Lo-Fi Version | Time is now: February 23rd, 2025 - 6:02 PM |
