> Power antenna issues
post May 19, 2006 - 11:05 AM
valerit1
Joined May 2, '06
From Nevada
Hi,
My power antenna at the last inches of extension makes horrible noises like
it is stuck trying to extend - real bad and loud. Any ideas howto fix it?
Thanks!
post May 19, 2006 - 11:32 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
thats exactly what mine does. and sometimes it wont go down by itself either, it'll just make that noise... it needs a little push when that happens
i took it out to try and figure out the problem and theres a little piece of the end missing from the plastic thing that pulls it down
get a new one or live with it...theres not much else you can do.
im just going to disconnect the motor [one of these days] so it stays down, i never liked that huge thing sticking up all the time anyway
I <3 Dustin---07/16/06
post May 19, 2006 - 1:19 PM
orvillescelica
That same thing happened to me a whle back ago. It also happened to my mom's camry as well.
My fix was ripping out the power antenna, disconnect the power cable and install an s2k antenna. My moms fix was trading her car in for a lexus. I think others here with the same problem installed a new motor.
post May 19, 2006 - 1:22 PM
eliaz
Joined Dec 28, '05
From Norway
Or you can just replace the antenna mast, the thing that extends, the antenna itself. smile.gif
post May 19, 2006 - 2:49 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
yeah its not the motor...that obviously works since your hearing it
you could just replace the antenna mast and plastic thingy
post May 19, 2006 - 3:09 PM
Stu37363
Joined Jun 30, '05
From Chattanooga, TN
yeah it sounds like the plastic piece inside broke, mine broke right in the middle so it wouldnt even try to go up or down, the replacement part for it was 47.79. i just replaced it two days ago, so if you need help doing it, i can explain it while its still fresh in my mind.
post May 20, 2006 - 9:58 PM
celicak
Joined May 20, '06
From williamsburg, va
QUOTE(Stu37363 @ May 19, 2006 - 3:09 PM) [snapback]435789[/snapback]
please do explain i'm having the same problem with mine that you had and i'm going to have to replace it here in the near future.
post May 20, 2006 - 10:41 PM
Jaws4God
Joined Mar 27, '04
The mast itself is metal, but there is a long plastic part that has teeth in it that the motor uses to raise and lower it. Mine was broken in half when I bought the car so it would go up halfway then make this grinding noise..
http://cgi.ebay.com/ebaymotors/Toyota-CELI...sspagenameZWDVW
post May 20, 2006 - 10:48 PM
94GT
Joined Feb 25, '04
From Fairfield, CA
I recommend replacing it with an aftermarket antenna. Check my reply on this thread for details. See end of post for part numbers and brands.
Antenna Thread
post May 21, 2006 - 2:27 PM
tin_foil
Joined Jun 7, '05
From Corvallis, OR
My celica is having the exact same problem. It's pissing me off. I have to help it raise and lower the antenna. I'm just planning on replacing it with an S2000 antenna soon.
post May 21, 2006 - 2:43 PM
celicak
Joined May 20, '06
also my radio gets really bad reception could this be part of the problem or would that be a totally different issue? the antenna is stuck in the up position but i get bad reception and i don't know why yet.
This post has been edited by celicak: May 21, 2006 - 9:54 PM
post May 22, 2006 - 5:26 AM
94GT
Joined Feb 25, '04
From Fairfield, CA
If it's getting bad reception in the up position it makes me think that something is disconnected or not grounded properly. Is your stereo after market or is it original? Have you ever worked on your antenna assembly before? I went through some antenna issues myself and when I finally just spent the 40 bucks to install the aftermarket one that I mentioned above it straightened everything out. I don't recommend replacing the mast because it's as costly as my entire new unit and the first time I replaced the mast it still was a little messed up and then it ultimately stopped working again not long after.
post May 22, 2006 - 6:11 AM
celicak
Joined May 20, '06
it's after market. I just picked the car up about a week or two ago and i don't think the person before me put the aftermarket antenna plug in it. a buddy of mine that i work with told me he had the same problem with his dodge stratus and then he bought an aftermarket plug attachment and it worked fine. also i decided to get the entire aftermarket assembly that you posted on your thread as it costs less than just the mast. thanks.
post Jun 21, 2006 - 1:08 AM
DomGT
Joined Apr 19, '06
From Long Island, NY
I'm using a black 9" antenna that is always up not motorized. Gets the job done and no more hassle with the oem antenna.
'92 Grey Mitsubishi 3000GT SL - Sold
'96 Black Celica ST 25th Anniversary - Sold
'99 Black Mitsubishi 3000GT VR-4 - Sold
'04 E250 Work Van - Going soon
'08 Grey Dodge Charger Work Car - Ordered
post Jun 21, 2006 - 1:11 AM
WH95TE
Joined Jun 16, '06
From Plantation, FL
Is there a list of antenna's that work/look good on the Celi? I know the s2k swap, but are there any other options?
post Jun 21, 2006 - 2:06 AM
Akira_g4
Joined Mar 15, '06
From Sunnyvale CA
I've had this similiar problem. my antenna just makes a noise like its trying to go down but it doesnt move. you cant even push the antenna down, it just stays there. Actually how do you even take out the antenna??? is there a thread or how to do that? maybe i can fix it if i can get into it.
post Jun 21, 2006 - 12:50 PM
elvasoshexai
Joined May 16, '05
From Toronto, Ontario
[start shameless plug]
here's a quick fix to your antenna issues:
http://www.6gc.net/forums/index.php?showtopic=35815
item #1
[end shameless plug]
06 Civic EX
My For Sale Thread
post Jun 21, 2006 - 9:45 PM
expedition2166
Joined Jun 14, '06
From bainbridge ga
i got a replacement mast and lil windup thingy new in the box it says its for 92-96 camary 90-93 celica convertible 90-93 celica hatchback they guy i bought it from said it would work on my 95 vertible celica but i dunno
post Jun 23, 2006 - 11:14 AM
b1gr3d
Joined Feb 25, '03
From Springfield, MO
i bought an autoloc hidden anteanea for $45. unplug the stocker. plug in the hidden, it has double stick adheisive on it so stick on on your back glass on the top where no one can see it. remove hte plastic trim on the hatch, tuck the wire and viola
Coming in 2010
post Jun 24, 2006 - 12:32 AM
Cutrara
Joined May 6, '05
From PA
My aftermarket power antenna was like $30
Lo-Fi Version Time is now: February 22nd, 2025 - 3:07 PM
