> Rear Washer not working
post May 19, 2006 - 11:45 AM
jcrog
Joined Mar 20, '06
My rear washer is not pumping fluid. the wiper is fine. can anyone help me diagnose where the problem is in the system?
front system is perfect...
thanks
This post has been edited by jcrog: May 19, 2006 - 11:46 AM
post May 19, 2006 - 12:13 PM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
cloged line? Pumps shot? Pluged outlet?
Couple of things could be wrong.
Worst case is probally something electrical.
but id toss it up to something being pluged up
Kawi Love
post May 19, 2006 - 12:48 PM
jcrog
Joined Mar 20, '06
how could i clear the line?
post May 19, 2006 - 12:55 PM
devilsden97
Joined Jun 13, '05
lines are harder to do, but the actuall nozzle u can do with a paper clip. Sometimes if u wax the car or wash it, u can leave stuff in the nozzle that hardens and blocks the flow. Lines shouldnt get blocked unless you didnt put the strainer in when u added the washer fluid, and u got something like a piece of leaf in it. Im not sure how u'd clear the lines. When u click to spray does it make a noise like its trying to pump something? Also there could just be air in the line, and i know mine takes a second or too to spray out of the back, its not instantanous like the front ones.
Kawi Love
post May 19, 2006 - 2:29 PM
Clipsetuner
Joined Sep 12, '03
From Portland , Oregon , United States
problem solved.
DTE
I am a thief.
do not buy anything from me.
post May 19, 2006 - 11:19 PM
Rayme
Joined Feb 18, '06
From NB, Canada
I'll take a rear wiper thank you
-Rémy
02 SiR, 08 250R
post May 19, 2006 - 11:58 PM
I believe the rear washer jet only works when you have the front squirting.
try squirting the front and at the same time, switch on the rear.
I will double check tomorrow.
post May 20, 2006 - 12:52 AM
chacha
Joined Dec 29, '05
From So-Cal
mines squirt over my top roof, the passenger side....anyone with a suggestion?
post May 20, 2006 - 2:12 AM
purplegt4
Joined Feb 7, '03
From Northern Virginia
QUOTE(chacha @ May 20, 2006 - 1:52 AM) [snapback]435920[/snapback]
the front? stick a paperclip/needle in there and adjust it!
post May 20, 2006 - 8:18 AM
Clipsetuner
Joined Sep 12, '03
Rayme - Wipers are useless as a whole, go invest in a big bottle of RainX
DTE
I am a thief.
post May 20, 2006 - 9:05 AM
CelicaQT
Joined Sep 29, '02
From Sterling Heights, Michigan
QUOTE(Batman722 @ May 20, 2006 - 12:58 AM) [snapback]435908[/snapback]
I belive you can just switch on the rear without doing the fronts at the same time. I had this problem also way back when. I just cleared the line by poking the hole with a needle (be careful though) and turned the rears on.
I had to hold it on for about 30 secs+ and then it started to leak out. Yes...I said leak because mine doesn't spray in the rear.
Anyone else's leak out and not spray in the rear too?
post May 22, 2006 - 1:04 AM
6gsillyca
Joined Jan 13, '06
From UnderTheGround403
I have the same problem as jcrog. The wiper wipes but no juice comes out. front workes fine. Didn't care enough to put to much effort into fixing it though...maybe if a fix is found i'll go do it biggrin.gif
post May 22, 2006 - 1:42 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
QUOTE(CelicaQT @ May 20, 2006 - 10:05 AM) [snapback]435976[/snapback]
mine do that! its so annoying! first of all i have to hold it for awhile, then it just drizzles out and does nothing...id like to know how to fix that too
I <3 Dustin---07/16/06
post May 22, 2006 - 7:30 AM
Cutrara
Joined May 6, '05
From PA
same here
post May 22, 2006 - 8:14 AM
vsideboy
Joined Mar 29, '06
From Hull, UK
Mine too just runs down the window it doesn't squirt out.
Also when I use the rear washer it sets off the front wipers going too as if its shorting somewhere, so I have to spray the front first then spray the rear. I don't think that you can use the front and rear washers at the same time because I thought it was the same pump for both?
post May 22, 2006 - 9:27 AM
jcrog
Joined Mar 20, '06
I checked the hole on the rear window and it is fine no clogs...
I will try using both to see what happens and reply here.
Also does anyone know if they are using the same pump? Because then it would mean it is a line or switch problem since my fronts work fine...
This post has been edited by jcrog: May 22, 2006 - 9:28 AM
post May 22, 2006 - 9:35 AM
devilsden97
Joined Jun 13, '05
QUOTE(hurley97 @ May 22, 2006 - 2:42 AM) [snapback]436536[/snapback]
QUOTE(Cutrara @ May 22, 2006 - 8:30 AM) [snapback]436564[/snapback]
same here
QUOTE(vsideboy @ May 22, 2006 - 9:14 AM) [snapback]436581[/snapback]
thats how it works. It doesnt need to squirt, it just drizzels out.
Kawi Love
post May 22, 2006 - 1:13 PM
jcrog
Joined Mar 20, '06
I tried eveything...holding washer button, both the 3 and 4 positions (according to manual), everything...
and no result.
any ideas????
Also they both use the same pump stated here:
http://aarc.epnet.com/application/8959/895...asher_Motor.htm
so it must be a line problem...
This post has been edited by jcrog: May 22, 2006 - 1:19 PM
Lo-Fi Version Time is now: February 24th, 2025 - 8:23 AM
