> Please Help, Glow Gauge Wiring
post May 19, 2006 - 4:15 PM
Pulse_of_Enigma
Joined Apr 16, '06
I just got my glow gauges today http://cgi.ebay.com/ebaymotors/i438-94-99-...78799QQtcZphoto
But I'm having problems with the wiring..
Yes, I read the Indiglo Gauge wiring how to in the how to section, but basically I dont know what I'm wiring to what wire and how to wire it.
There's only 2 wires with the Glow Gauges, a red and black, power and ground. From there.. I don't know where to start.
I need help fast..
MySpace
AIM: phob0z
(Yes, That's Me)
post May 19, 2006 - 5:26 PM
Pulse_of_Enigma
Joined Apr 16, '06
...anyone?
MySpace
AIM: phob0z
(Yes, That's Me)
post May 19, 2006 - 8:14 PM
Pulse_of_Enigma
Joined Apr 16, '06
Well, nevermind, I figured it out... but now all the lights associated with the Dimmer don't work.
MySpace
AIM: phob0z
(Yes, That's Me)
post May 19, 2006 - 10:17 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
try wiring your red (power) to the guage lights fuse.....its goin be on when teh cars on.....but hey better than splicing up the dimmer.....
post May 20, 2006 - 12:33 AM
Culpable04
Joined Apr 17, '06
From New Jersey
^^^that's how I got mine set up, I think it's the best way because if you splice up the dimmer wires you may have problems later ( may be overloading the circuit )
I'm not an expert, but I'm sure someone here can tell you exactly what to do.
post May 20, 2006 - 12:47 AM
chacha
Joined Dec 29, '05
From So-Cal
What i did for mines was, i cut the fuse box of the guages, the black and the red wire...split it into two....connect the black somewhere down the fuse box underneath the steering wheel for grounding...basically unscrew a bolt and screw the bolt back in to hold the black wire in place...for the red wire...i attached in one of the fuse plugs...i belive a 12v or 7v...it worked...
post May 20, 2006 - 12:50 AM
Stu37363
Joined Jun 30, '05
From Chattanooga, TN
i just wired mine into the brake light fuse so it comes on whenever the lights are on.. but yeah, i wouldnt wire it into the dimmer, they are designed to take 12 volts (well designed to take a certain amount of current before the power hits the built in dimmer switch depending on what kind you have)
post May 20, 2006 - 2:36 PM
blu94gt
Joined Mar 23, '05
From Kansas City
i almost bought those except i don't like how the whole center of the gauge lights up.
1999 Celica GT
post May 20, 2006 - 2:48 PM
Pulse_of_Enigma
Joined Apr 16, '06
Well as I said before its wired and it works. The only things is all the light that are associated with the dimmer, such as the 194 bulbs in the cluster that light up the needles and whatnot, and the lights in the climate control don't come on at all.
My new gauges are not wired into the dimmer, although the green dimmer wire was cut, but was re-wired back together.
I don't know how to get those lights to work again...
MySpace
AIM: phob0z
(Yes, That's Me)
post May 20, 2006 - 4:28 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
did u connect the dimmer harness???.....
post May 20, 2006 - 8:39 PM
Pulse_of_Enigma
Joined Apr 16, '06
QUOTE(DeW_H0e_GT @ May 20, 2006 - 4:28 PM) [snapback]436071[/snapback]
Yep..
MySpace
AIM: phob0z
(Yes, That's Me)
post May 20, 2006 - 10:20 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
checked the fuses???....try takin your dimmer apart and solder the wire back on (if u havent already)....that way u get a direct conection.....
post May 21, 2006 - 1:15 PM
Pulse_of_Enigma
Joined Apr 16, '06
I just figured it out. So no one needs to give any more suggestions, lol. Thanks though to everyone else.
MySpace
AIM: phob0z
(Yes, That's Me)
Lo-Fi Version Time is now: February 23rd, 2025 - 10:44 PM
