7a-fe megasquirt questions |
May 22, 2006 - 2:36 PM |
Enthusiast Joined May 22, '06 From Dover,DE Currently Offline Reputation: 0 (0%) |
Ok, Here is the deal.
My buddy has a 93 Geo Prizm and he has the 7a-fe in it which i tracked it down and see that the 6g celica does too, ok now to the good stuff I see alot of you celica guys recommend the MegaSquirt Which I love, I have it on my Neon and Mustang and we bought it and would like to use it on my buddies car, however i have not seen any use the stock dizzy with the 7a-fe and megasquirt, i know i could just get the EDIS-Ford stuff but we would like to use the stock dizzy and such i also see the alot of 4a-fe and 4age guys have used the megasquirt how much different is the engine wiring and pcm for the 7a-fe motors from the 4a-** motors and can i use and install document for a 4a-** motor on a 7a-fe motor? thanks richie |
May 22, 2006 - 2:43 PM |
The wiring is pretty different.
You can probably use the stock distributor as a crank position sensor and one of the stock sensors(I've seen Ne used on a AE101 4A-GE) and run the MSnS-extra firmware. I'm not too familiar with the 7A-FE distributor setup though. -------------------- New Toyota project coming soon...
May 22, 2006 - 2:50 PM |
QUOTE(Coomer @ May 22, 2006 - 2:43 PM) [snapback]436692[/snapback] The wiring is pretty different. You can probably use the stock distributor as a crank position sensor and one of the stock sensors(I've seen Ne used on a AE101 4A-GE) and run the MSnS-extra firmware. I'm not too familiar with the 7A-FE distributor setup though. i wonder where i can get a 7a-fe wiring diagram if i have to buy a book i am going to be pissed, lol richie |
May 22, 2006 - 3:05 PM |
Enthusiast Joined Mar 25, '06 Currently Offline Reputation: 0 (0%) |
QUOTE(238ur50 @ May 22, 2006 - 12:50 PM) [snapback]436696[/snapback] QUOTE(Coomer @ May 22, 2006 - 2:43 PM) [snapback]436692[/snapback] The wiring is pretty different. You can probably use the stock distributor as a crank position sensor and one of the stock sensors(I've seen Ne used on a AE101 4A-GE) and run the MSnS-extra firmware. I'm not too familiar with the 7A-FE distributor setup though. i wonder where i can get a 7a-fe wiring diagram if i have to buy a book i am going to be pissed, lol richie http://aarc.epnet.com/application/8959/8959.htm try this -------------------- ----- '94 ST hatch --- Yellow ----- |
May 22, 2006 - 3:38 PM |
QUOTE(phonex98 @ May 22, 2006 - 3:05 PM) [snapback]436709[/snapback] QUOTE(238ur50 @ May 22, 2006 - 12:50 PM) [snapback]436696[/snapback] QUOTE(Coomer @ May 22, 2006 - 2:43 PM) [snapback]436692[/snapback] The wiring is pretty different. You can probably use the stock distributor as a crank position sensor and one of the stock sensors(I've seen Ne used on a AE101 4A-GE) and run the MSnS-extra firmware. I'm not too familiar with the 7A-FE distributor setup though. i wonder where i can get a 7a-fe wiring diagram if i have to buy a book i am going to be pissed, lol richie http://aarc.epnet.com/application/8959/8959.htm try this now i just need to find it for the 4a-** engines and i will be golded, also one of the wiring diagrams just has the Intergrated Ignition Assembly, now this could mean a few things 1. this motor doesn't have a distributor 2. or it does but is different from the 96-98 7a-fe motor i can tell you for a fact that the prizm motor has a dizzy, now can someone tell me if all the 7a-fe motors have a distributor? however i thinking being the motor is in a 93, then motor would be an obd1 motor or pre-OBD-II motor however toyota would say it and from the pic i see in the manual the prizm coil should have 4 pins on the distributor which are G+, G-, NE+, NE - thanks richie This post has been edited by 238ur50: May 22, 2006 - 4:00 PM |
Lo-Fi Version | Time is now: December 1st, 2024 - 5:50 AM |
