GT4 Riser Blocks from Chrisc, Questions |
May 24, 2006 - 11:02 PM |
Enthusiast Joined Aug 31, '02 From Virginia Currently Offline Reputation: 4 (100%) |
I ordered the riser blocks from Chrisc off Ebay. Before I go off asking him questions that I don't know, just had a few questions for those that have bought them from him:
What are they made of? Fiberglass or plastic (like the bumper)? Will I have to drill holes in my spoiler to match up with the block holes? It appears that the blocks have pre-drilled holes at the top. The blocks are painted a black gelcoat? If I paint over this (red), do I need to prime it first, or can I just paint right over the black? Finally, I have a red GT (see pics)...leave the blocks black or paint them red? Thanks! |
May 25, 2006 - 12:46 AM |
Moderator Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
1. Fiberglass
2. No drilling required for the two post hatch 3. Black gel coat 4. this is up to you DEF -------------------- I will return one day. |
May 25, 2006 - 5:46 AM |
QUOTE(defgeph @ May 24, 2006 - 10:46 PM) [snapback]437728[/snapback] 1. Fiberglass 2. No drilling required for the two post hatch 3. Black gel coat 4. this is up to you DEF Thanks man. For #3, Did you do any kind of prep work before painting (sanding or priming) before painting (if you painted yours at all)? |
May 25, 2006 - 6:02 AM |
yes, i would give them a light sanding with 320 before you do anything.
the more you "prep" them, the better theyll look. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
May 26, 2006 - 10:12 AM |
I would say 600-800 wet sand, use clean water. Then rinse them with clean water let them dry and paint them.
Manny is right, the more prep work you do the better the paint will come out. -------------------- I will return one day. |
Lo-Fi Version | Time is now: November 26th, 2024 - 11:30 PM |
