2 Pages V  < 1 2
> How to install 96+ OEM Sideskirts on a 94-95 6gc, finished both sides... updated 05/25/06
post Jul 4, 2009 - 2:13 PM
how is that double tape holding out?
post Jul 4, 2009 - 3:27 PM
azian_advanced
Joined Apr 18, '05
From Calgary
the double side tape is still holding on most of the edge. the edge that goes between the door and the rear wheel. double side tape works fine especially if you plan on removing them off the car without damaging the paint too much. but for a more permanent install, there's this stuff that works much stronger and lasts longer my cousin uses for his customers and it's essentially the same stuff used to hold windshields to the car. i'll be considering this when i install new sideskirts to my next car.
post Jul 4, 2009 - 6:05 PM
whats it called?
post Jul 4, 2009 - 8:25 PM
azian_advanced
Joined Apr 18, '05
From Calgary
i'd have to ask him, i don't remember it
post Oct 4, 2009 - 12:23 AM
BeefyT
Joined Feb 19, '08
From Anaheim,CA
would i be able to order the clips that the side skirts came with,(ones i would have to drill to install the side skirts) from a toyota dealer? does anyone know the part number?
lol
post Oct 4, 2009 - 12:36 AM
azian_advanced
Joined Apr 18, '05
From Calgary
from Toyodiy.com (page 3 of 3)
Part number: 90467-10162 (18 total for both sides)
$0.80 /each
post Oct 4, 2009 - 11:50 AM
BeefyT
Joined Feb 19, '08
From Anaheim,CA
QUOTE (azian_advanced @ Oct 4, 2009 - 1:36 AM) *
$0.80 /each
that part number isnt coming up when i search it...??
lol
post Nov 2, 2013 - 6:46 PM
OldskoolTizok
Joined Jul 16, '13
From Heber, CA
7yr old post will serve me well, I will be performing this tomorrow thanks smile.gif
post Nov 3, 2013 - 9:23 AM
jeffrosie
Joined Sep 11, '08
From Surrey Unitedkingdom
Can use Tiger Seal or PU18 Sealant.
post Jun 26, 2014 - 8:14 PM
doory100
Joined Jun 21, '14
From Ottawa, Ontario, Canada
I'm thinking of installing mine soon. I have placed the skirt on a large sheet of paper and cut out the outline of the skirt itself with box cutters and then poked the clips through the paper silhouette. i was planning on putting the silhouette on the car and using it as a template for drilling the holes. then putting the side skirt on and screwing the bottom on. also I plan on filling the rocker with rust proofing to avoid any rust. I live in Canada and I'm worried about the tape failing during the winter. Any suggestions??
post Jun 27, 2014 - 11:12 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Dont try to drill out the holes on the rocker panel, if even a single one is off by a few millimeters, and they will be, it wont fit correctly.
Doublesided tape works sspectacularly well along the top of the sideskirt. Adhere it to the car, then jack that side (put the jacks under the suspension not the pinch weld on the rocker panel since youre working here) and drill out the 6 or 7 holes along the underside of the rockerpanel for the clips. These are easier to drill since you already have a properly aligned sideskirt as a stencil.
post Jul 12, 2014 - 7:45 AM
doory100
Joined Jun 21, '14
QUOTE (Special_Edy @ Jun 27, 2014 - 11:12 AM) *
Drilling out the holes is way to much work. Im just going to use self tapping screws with washers and the tape like you suggested.
post Jul 13, 2014 - 6:58 AM
doory100
Joined Jun 21, '14
QUOTE (doory100 @ Jul 12, 2014 - 7:45 AM) *
Drilling out the holes is way to much work. Im just going to use self tapping screws with washers and the tape like you suggested.[indent][/indent]
Took me 45 min a side to install with the self tapping screws. And cost me $8 for screws and washers. The screws gave me more room for adjustment in order to get the skirt lined up.
post Jun 21, 2016 - 9:44 AM
Constantine
Joined Jun 2, '16
From Toronto, ON
QUOTE (doory100 @ Jul 13, 2014 - 7:58 AM) *
now that its been a couple of years how are the screws holding up? I've heard they can get loose overtime? I've also heard they start rusting out which starts rotting out the car. have you had either of those problems?
2 Pages V  < 1 2
Lo-Fi Version Time is now: April 23rd, 2025 - 6:59 PM
