Closed TopicStart new topic
> SOLD 1994 Celica GT "ST205 conversion" SOLD, SOLD SOLD SOLD SOLD SOLD SOLD SOLD
post May 25, 2006 - 10:47 PM
iburnslabs
Joined Sep 22, '02
From colorado
Ok folks well heres the scoop, ive only owned the car for about a year now and it is a blast! but i have an investment that i MUST take that is forcing me to sell either the supra or the celica. so..... well.... the celica must go lol, too much $$ into the other car by comparison to think about getting rid of that one.. anyways for those that dont know about the car....
It has been successfully converted to AWD with all STOCK parts off a 1997 ST205 WRC!!! yes it has a WRC motor as well. I have put about 8 k miles total on the car since i got it. drivetrain is solid, motor is solid (3~5% leakdown on all cylinders) about 90k US miles on the motor (pulled @ 100k Kilometers in japan) i have replaced so many dang things on this car that it needed so i will try and list them all for you but im sure im missing some.. also comes with LOTS of spare parts and such... I DONT HAVE GOOD PICS YET !!! i WILL be taking LOTS of good pics after i clean up the interior this week and posting them here so please be patient, i just need to get the word out asap so im starting the thread with only a few miserable pics lol... anyways heres a list of mods/matienence
Mods
AWD conversion (duh)
3rd gen 97 WRC motor/tranny
ST205 brakes (pads still good) (ABS removed)
ST205 front bumper (w/all grills and foglights not mounted yet) + turn signals of course
ST205 hood w/ all grills (i have a jdm hood latch not installed yet , hood closes as is tho)
17" TRUE Grahm lights (bronze) with brand new 225/40/17 summer tires + spare set of Blizzaks (3K miles)
3" downpipe (cat removed)
3" axle back exhaust (stock 2 1/4 mid pipe still in place)
apexi rev speed meter
apexi boost gauge
apexi S~AFC Tuned @ 11.5:1 A/F (dyno chart included with a/f printout) (265 AWHP SAE corrected 5400 ft)
CT20b turbo (stock)
HKS intake
Air/Water IC running all the time
Upgraded flexalite DUAL fans dual 12" smile.gif this sucka stays cool!!!
upgraded thicker stock style radiator
ACT Street disc and HD pressure plate (5 k miles)
Blitz SBCID boost controller
ST205 rear strut tower brace
ST205 WRC wing raiser blocks
ST205 superstrut suspension (HUGE grin)
GAB 4 way adjustable struts ($500 each for fronts .. not cheap)
TRD 25mm lowering springs (Brand new from TRD japan 2k miles ago)
custom mounted 10 gallon fuel cell (tank does not fit with rear end)
ST205 rear diff (LSD)
MINES ECU with upped boost cut + rpm cut... maps up to 1.6 bar i belive (ive hit 1.5 in higher gears)
Repair/Matenience
Rebuilt lifetime warranty front axles
Newer T~belt and W~Pump (15K miles or so)
Newer valve stem seals (15K miles as well)
New yellow top Optima battery
New clutch (as mentioned above) OEM toyota throw out bearing
ALL fluids flushed.. i mean ALL including rear diffy
Oil changed every 1K miles.. .im NOT kidding 1K miles, once it looks dark i change it.. same as my other car .. call me anal but hey it dont hurt smile.gif always run 5w30 sythetic blend Valvoline
tires as mentioned above
low milage figure of 8 links replaced in suspension (expensive.. and i have an extra one too)
Low milage lower bars and upper bars (have more in the garage too)
New motor mounts (2) that were bad
im sure theres more... i will update if i need too, please ask any ?'s you might have as well in this thread or by PM.
Spare parts
(1) figure of 8 link
(2) sets of lower bars ($450 each from fensport i think lol)
(2) front stock struts and springs (30k kilometers) same as parts above....
spare stock hood anyone want it? lol
might be more.. ill have to check........
and im sure everyone wants to know... whats it run?? well keep in mind im @ 5400 elevation up in denver, our 1/4 mile times are about .50 ~ 1 sec slower than sea level times due to air restrictions lol.. anyways after the tuning as it sits...
ET 13.3x
MPH 101.x
60' 1.74
if you cant get this car into the 12's @ sea level you need to learn how to drive smile.gif anyways thats my spill of the guts... all i ask guys is please put this to a good home, its a very rare car 1 of 2 or possibly 3 known to be converted.. it needs a little paint work but mechanically its 110% i guarentee. all work done by myself
o ya.. and its a 1994 car with 180,xxx miles on the chassi , the 4th gear synchro is a tiny bit grindy on the downshift too.. its nothing bad, has never gotton worse.
$11,000 FIRM (unless you have a CHEAP daily driver for trade in with the price)
ive got 5K+ into it plus i paid 10k + 1K shipping for the car itself.... not to mention the prior owner had more than 10k into it smile.gif thanks for looking
EDIT : Car is a 5 Speed smile.gif
This post has been edited by iburnslabs: May 31, 2006 - 6:50 PM
94 Supra~12.10 @ 114 mph 1.74 60' @ 5800 elevation STOCK FUEL! (SOLD)
94 ST205 (converted) 13.1 @ 101.68 mph 1.71 60' @ 5800 elevation (SOLD)
95 ST205........ 495 AWHP under the knife for a better engine build then for sale....... 600 awhp here i come!
post May 25, 2006 - 10:52 PM
iburnslabs
Joined Sep 22, '02
From colorado
post May 26, 2006 - 1:57 AM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
wow thats impressive. but thats a lot of money. we need more pics.
post May 26, 2006 - 2:32 AM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
I was just admiring your car in your profile the other day. Awesome vehicle.
post May 26, 2006 - 6:25 AM
ZoomZoom
Joined Apr 7, '04
From Toronto
dibs on the st205 hood latch if you're selling it separate.
Please let me know.
Thanks
post May 26, 2006 - 7:52 AM
Gary
Joined Aug 28, '04
From FLA USA
Kosta, does the car still have A/C?
_Gary
post May 26, 2006 - 11:01 AM
iburnslabs
Joined Sep 22, '02
From colorado
QUOTE(Gary @ May 26, 2006 - 6:52 AM) [snapback]438147[/snapback]
it DOES have A/C and it worked fine untill we pulled the motor/trans out for refreshing... now when you use it, the a/c light (on the button) flashes when you push it in... im not sure what i missed.... im sure its easily fixed since it did work just fine before that. proboby a wire or something?
post May 26, 2006 - 11:06 AM
iburnslabs
Joined Sep 22, '02
From colorado
QUOTE(CheesyLobster @ May 26, 2006 - 12:57 AM) [snapback]438119[/snapback]
well it is a lot of money... being that 11,000 is alot of money in general. but really, the money put into this car is WAY more than 10,000 itself, and the custom fab work and labor time. and all the new parts.... and considering the car itself in stock form would be worth a couple grand itself... id say its a bargain smile.gif i bought it for 10k when it needed a SLEW of work only becuase this is the only LEGAL way to won an AWD 6th gen in the states. and i didnt want to do all the fab work myself.. including the wiring and all that mess... ya but anyways, more pics to come soon, i need to wash it and clean it up so everyone can see the real condition of the car, dont want to put up a dirty car for sale lol.
post May 26, 2006 - 11:19 AM
iburnslabs
Joined Sep 22, '02
From colorado
also i forgot to mention it has Recaro seats from a JDM ITR (integra type R) and JDM folding mirrors with switch properly installed in factory location. my email address is sales@22psi.com thanks
~Kostas
post May 26, 2006 - 12:20 PM
thats a fair deal and an awesome car! about the only way to get a real awd gt4 in america. if i didnt already have my car, i would buy that in a heart beat.
post May 26, 2006 - 2:23 PM
fastcelica20
Joined Apr 4, '06
From Minnesota
are you in a hurry to sell the car?
post May 26, 2006 - 6:03 PM
j0e_p3t
Joined Dec 8, '05
From torrance/carson, ca
damn, i've always wanted a gt-four. post more pics. i'm interested but i doubt i'll be able to buy it. so good luck with the sale.
post May 26, 2006 - 6:12 PM
GMan
Joined Jan 17, '04
From Boston, MA
I am breaking open the cookie jar, just got to see how many pennies I got. rolleyes.gif
Not a bad deal at all IMHO.
When do you move on to EBay ? I'll PM U if I can gather all the cash. biggrin.gif
The AC is blinking out a code if you can count the flashes.
Usually the rubber/metal hose on the AC compressor splits & leaks.
I had the hose replaced, new refr put in and my AC worked again.
Regards;
post May 27, 2006 - 10:35 AM
iburnslabs
Joined Sep 22, '02
From colorado
QUOTE(GMan @ May 26, 2006 - 5:12 PM) [snapback]438337[/snapback]
Regards;
wow thats good info for whoever buys it (maybe you) smile.gif i know you want it g~man sicne you already drove it and know what it looks like/ drives like... i hope you buy it since i know its going to a good home. and again i apologize about the pics, im going to go wash it right now and take pics ill have them up soon hopefully, time crunch for me to goto work...
and to answer the other question, yes im in a huge hurry to sell it becuase of this investment i have to take advantage of, but this does not mean im gonna drop my pants on the price. i already have made the price fair for what i paid, what i put into it/labor time. and not to mention whats a half cut of a gt4 WRC cost??? gotta take into conisderation what the parts are worth just sitting under the car. anyways ill be back with pics asap...
Ebay... hopefullly i dont have to do that, i want someone from the Celica community to buy it, not some rich dad buying it for a first car for some kid to go smash it or something. PUT THIS TO A GOOD HOME PLEASE !!!!!
~Kostas
post May 27, 2006 - 11:24 AM
celicaST
Joined Jun 23, '05
dang, i was really looking forward to seeing this at the meet in a couple weeks frown.gif. if its not sold by then i hope you can still bring it up with the supra. i actually think i saw your car in denver a couple weekends ago. saw a black 6g parked with gold wheels and gt-4 wing, and im sure theres not too many of those around in denver. if only i had the cash and wasnt it college... up for a trade? my car only has 51k miles, makes a great dd wink.gif hey had to give it a shot tongue.gif best of luck with the sale. absolutely stunning car. just please dont sale it to some undeserving high school kid with rich parents.
post May 27, 2006 - 12:35 PM
iburnslabs
Joined Sep 22, '02
From colorado
i AM up for trades but i need most of the cash, so depends on what your letting your car go for.. PM me if interested
post May 27, 2006 - 12:46 PM
iburnslabs
Joined Sep 22, '02
From colorado
ok guys i HAVE TONS of pics, but i cant find my stupid cable for the computer and im LATE for work, ill post up pics tonight i promise!! sorry for the delay.
~Kostas
post May 27, 2006 - 1:28 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
Wanna trade cars ?
I will return one day.
post May 27, 2006 - 10:39 PM
iburnslabs
Joined Sep 22, '02
From colorado
ok guys well i cant find the cable for the stupid camera... arg im so pissed ... anyways i have another camera (only 2 megapixel) but i will re take all the shots tomorrow and repost them... ugh im sorry guys i know i promised them but i tried to use the better camera and i got hosed... anyways ill have them up tomorrow. sorry again
~Kostas
post May 27, 2006 - 10:55 PM
iburnslabs
Joined Sep 22, '02
From colorado
taking some garage pics .... wont be the best but ill post them for now... give me a few
Lo-Fi Version Time is now: January 12th, 2025 - 2:47 AM
