3 Pages V   1 2 3 >
> How To Install GT-Four Raiser Blocks on a 94/95 Hatch
post May 26, 2006 - 2:36 PM
azian_advanced
Joined Apr 18, '05
From Calgary
How to install GT-FOUR raiser blocks
Tools used:
- A set of pics or a flat screwdriver
- A ratchet with 10mm and 12mm sockets
- Adhesive Remover (or GooGone) Spray and a cleaning rag
- A Hand Saw
- A Power Drill with 15/64" Drill Bit
- A 'super' long Phillips Screwdriver (kinda overexaggerated) 10" is fine laugh.gif
Optional: A long magnet to pick up screws dropped inside the block
Parts needed:
- The GT-Four Raiser Blocks themselves
- 4 x 90159-60414 Screw ($.52 USD each) or any 4 short, stubby screws/bolts that have deep threading.
Optional:
- 1 x 76882-20090 Spoiler Gasket RH
- 1 x 76881-20090 Spoiler Gasket LH
Image taken from Complete information for SS-III replica makers smile.gif by malpaso.
Note: You can PM vincent_doggy for GT-FOUR raiser blocks, keep a look out on eBay for a pair, or buy new from the dealer (ie. 1sttoyotaparts.com) using Part Numbers: 76087-20916 and 76088-20914 ($262.48 for both)
Intro
I bought my GT-FOUR blocks a little over a year now and have been waiting for this summer to install them. They are replicas of the authentic version and they fit satisfyingly well.
The pic below is how it looked right out of the box.
Here's how they look during its prepping stage.
After being painted.
Procedures
1. Remove the lower hatch trim cover. For this you can just use your hands or you can use the picks.
2. Remove the lower hatch trim. For this I used my hands but you can also use the picks or flathead screwdriver. There are a total of 14 clips. There are two clips directly in front of the cover opening. Then work your way around. I would recommend using your hands and push down from the inside center. By using the screwdriver and pulling from the edges, you may risk damaging the trim plastic or even the clips.
3. Remove these rubber plugs on both sides. Behind them there's a 10mm bolt holding the spoiler.
4. Using the ratchet with the 10mm socket, remove the two 10mm bolts holding the spoiler on each side.
5. Remove the spoiler. It should easily come right off.
I kinda like that spoilerless look.. hmmm.....
6. Notice a white peg attached on the bottom of the spoiler. These will need to be sawed off both sides with the handsaw because the replica spoiler blocks doesn't have a hole to support these. But you can skip this step if you have a pair of authentic OEM blocks.
7. Drill holes through the bottom of the spoiler. There are two little markings or indents to show 5here you should drill. For this part, use the 15/64" drill bit.
8. Use that long screwdriver and place the screw to the tip vertically upward. Then insert it into one of the holes of the block (I chose to do the deeper side first). Then flip it over and screw it in to the spoiler.
If you're wondering about the original spoiler gasket, you can just leave it on.. i tried removing mine only to find out that it's stuck on there. after i pulled on it, it started to tear, so i just left it on.
9. Now you'll need to screw in the other hole. You can either flip the entire spoiler over and repeat step 10. But what i did was i used double-sided tape and stuck the screw in place. Getting the screw into the hole through the block and spoiler is probably the hardest step. If you happen to lose the screw, just use the magnet to pull it out.. or you can flip it, shake it until it comes out of the hole.
Here's how they look inside with the screws in place.
and here's how the whole spoiler looks after.
10. Prior to putting the spoiler on the hatch. Be sure to remove the dirt left under. You can use a moist cleaning rag and simply wipe it off. But for the adhesive leftover, use the adhesive remover spray, or you can use a warm damp rag and wipe it off.
This is where you apply the spoiler gaskets (if you bought them) and stick them onto the bottom of the raiser blocks.
11. Now place the spoiler onto the hatch ensuring that the holes line up with the bottom side.
12. Install the bolts back on. Once on, try opening and closing the hatch. If you hear some rattling when you close the hatch shut. It means the bolts aren't tightened hard enough. Slowly tighten them as you'll hear some of the fiberglass from the blocks starting to crisp. It just comes to show the tension being applied as the screw pulls on to the block. When you no longer hear the buzzing or rattling, then you know they are tight enough.
13. Now don't get too excited, you still have to put the hatch trim back on. It's pretty straight forward, just line up the clips and push on them.
14. Reattach the trim cover.
15. And plug in the rubber plugs.
16. Congrats! You are now finished!
Total Time:
3 hours including breaks (haha, yeah i took some believe it or not), all the picture taking and finding which drill bit works best with the screws.
but if i were to do it again, it would probably take only 1 hour or less
The End Result
Before and After
This concludes the installation of the GT-FOUR spoiler blocks
Other Spoiler How-To Threads:
- Converting from a 3-Post Spoiler (96-99) to a 2-Post Spoiler (94-95) by 97lestyousay
- Converting from a 2 or 3-Post Spoiler to No Spoiler (Spoilerless) by hurley97
any questions? just post.
This post has been edited by azian_advanced: Jan 13, 2010 - 9:02 AM
post May 26, 2006 - 2:45 PM
awesome write up!
post May 26, 2006 - 2:59 PM
azian_advanced
Joined Apr 18, '05
From Calgary
oops.. i mentioned 15/64" drill bit on the tools used list while i posted 14/64" drill bit in step 9.
just to clarify, use 14/64" first. it should still work just you'll have a tighter grip with the screw (which is what you want)
^fixed in original post
This post has been edited by azian_advanced: Jan 13, 2010 - 8:40 AM
post May 26, 2006 - 3:08 PM
eliaz
Joined Dec 28, '05
From Norway
post May 26, 2006 - 3:12 PM
snapshotgt
Joined Oct 12, '05
From Texas
~snap
post May 26, 2006 - 3:26 PM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
post May 26, 2006 - 3:35 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
This will be added to the stickies.
I will return one day.
post May 27, 2006 - 9:10 AM
Celicav
From Virginia
MAN, Thanks so much! This is IMPECCABLE timing since my blocks are on the way from Chrisc!!! I may PM you to talk about the painting process.
This post has been edited by Celicav: May 27, 2006 - 9:11 AM
post May 27, 2006 - 10:07 AM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
x2!
You rocked the how-to once again, GREAT write up.
post May 27, 2006 - 11:02 AM
great job man!
looks great!
post May 28, 2006 - 1:58 AM
Slow-lica
Joined Sep 26, '05
From New Zealand
That's an awesome write-up biggrin.gif Are the part numbers in that diagram for the spoiler gaskets?
post May 28, 2006 - 6:45 AM
azian_advanced
Joined Apr 18, '05
From Calgary
those are the spoiler gaskets for the blocks, not for the original 2 post spoiler.
post May 28, 2006 - 8:24 AM
trdproven
Joined Aug 2, '05
From Guam
very detailed writeup... good job!
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post May 28, 2006 - 10:57 PM
celicurr
Joined Jan 29, '06
From Kitchener, ON, CA
wow man! good job!
post Jun 1, 2006 - 2:50 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
very nice and detailed. Off topic though, how much did it cost to get the blocks painted? If I had any other color other than black I would leave them, but that would look ghey.
**** Photobucket
post Jun 4, 2006 - 11:24 PM
Celicav
From Virginia
WELL, I just finished installing my Blocks tonight and this write-up was my guide for sure. Thanks again Gerald!! I just have a few things to add to clarify/make things a little easier:
1. There should only be TWO 10 mm bolts on each side of the spoiler that you have to take off when removing the spoiler. The pic of the ratchet undoing the 12 mm bolt with the big rubber thing around it...no need to remove that...all those bolts do is hold the big rubber cushion in place that cushions the impact when you close the gate. Also, make sure you secure the spoiler when getting the last couple of bolts off (duh).
2. When working with the spoiler, the best thing to do is lay it across two cushioned chairs (for the drilling of holes, securing the blocks to the spoiler). When securing the blocks, the easiest thing to do is put some strong tape on the screw driver and on top of the screw, and have the blocks upside down laying on top of the spoiler. Also, a FLASHLIGHT is a big help in guiding the screw down into the hole.
3. Personally, I did not have the gaskets to place between the gate lid and the blocks. To have some cushion and get a weather proof seal, I placed some 3M double sided tape all around the screw holes on the gate lid first. You need to worry most about the screw hole that is located under the big inside trim piece that we had to take off.
Hope this helps! I'll add a pic soon.
post Jul 6, 2006 - 9:56 PM
Rayme
Joined Feb 18, '06
From NB, Canada
If I might add someting, instead of cutting the two nipple of the spoiler, I drilled two holes in the block to make it fit, I guess it good either way but I liked having those as a guide to hold the spoiler in place instead of only the screws. smile.gif
-Rémy
02 SiR, 08 250R
post Jul 7, 2006 - 12:48 AM
WH95TE
Joined Jun 16, '06
From Plantation, FL
very nice, I want some blocks.
post Feb 17, 2007 - 1:12 PM
97lestyousay
Joined Jul 7, '03
QUOTE(azian_advanced @ May 26, 2006 - 11:59 AM) [snapback]438280[/snapback]
Excellent right up!!!
You won't find a 14/64 drill bit so just use a 7/32. biggrin.gif
This post has been edited by 97lestyousay: Feb 17, 2007 - 8:36 PM
JDM guy made me do it.
post Feb 17, 2007 - 7:02 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
very detailed. looks awesome too.
great writeup.
3 Pages V   1 2 3 >
Lo-Fi Version Time is now: April 23rd, 2025 - 3:04 PM
