Battery to boot... |
May 28, 2006 - 12:18 AM |
Enthusiast Joined Mar 17, '05 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
Finally got round to taking a couple of pics. After finding the time the other week, battery was moved to the boot making room for the new WAI and cold air box set-up which is currently in the planning stage.
Next step is to cut off the OE battery tray and remove the rad overflow bottle which will be replaced with a custom made one. This will allow a custom cold air box to be mounted in that space with a short run to the turbo. Air feed to the box/filter will be from underneath. A steel battery tray was fabricated which was securely bolted to the crossmember just behind the rear seats. Once all connected, a simple ally box was powdercoated and then fixed in place with 2 small bolts. Job done. Definitely not much room in the boot on the WRC spec 4 due to the full size spare wheel. A sub box doesn't exactly help either Gary -------------------- 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
May 28, 2006 - 12:29 AM |
Enthusiast Joined Jun 12, '05 From Box Springs, GA Currently Offline Reputation: 0 (0%) |
interesting work, man. like the pics...like the GT4 even more!
but yea, don't plan on carrying much cargo with all that in the boot. -------------------- |
May 28, 2006 - 12:55 AM |
Enthusiast Joined Nov 7, '05 From Brisbane, Australia Currently Offline Reputation: 0 (0%) |
nice work. i was actualy thinking of doing this, might give it a go. see how things end up i spose
May 28, 2006 - 2:19 AM |
Enthusiast Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
I'm gonna do the same thing. Placing the Battery in the boot. Gonna remove al the back materials thats there and weld a frame onto the chassis. Where did you put your ground wire? Welded a bolt to the chassis?
-------------------- JDM Powerplant installed, BPU coming very soon!
May 28, 2006 - 4:48 AM |
Enthusiast Joined Sep 17, '05 From Newcastle / UK Currently Offline Reputation: 4 (100%) |
When I move mine I used one of the rear strut top mount fixings for the earth point.
-------------------- 1994 JDM GT4 WRC
May 28, 2006 - 2:08 PM |
QUOTE(Kadett @ May 28, 2006 - 2:19 AM) [snapback]438585[/snapback] Where did you put your ground wire? Welded a bolt to the chassis? Just utilized an existing bolt hole on the rear crossmember. Stripped the paint back to bare metal and used a nut & bolt. Job done. Gary -------------------- 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Lo-Fi Version | Time is now: December 3rd, 2024 - 12:56 PM |
