![]() Administrator ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '02 From Seattle, WA Currently Offline Reputation: 14 (100%) ![]() |
This thread is going to be updated as I do some bodywork and paint my car. I always love these progression threads myself, so I figured I'd make my own this time.
![]() Please post your comments as I go along. Since this is my project car and has a salvage title due to vandalism, I'm not doing things that I would if this were going to be a super nice paintjob, like having the rear side windows removed (Average quoted price was $200 around here) and using urethane base coat/clear coat paint (Expensive! And two different types of coats means twice the chances of me messing up.) I'm going to use an enamel of some sort, and going to stick with yellow probably. Anyway, on with the project: Day One Day one started with washing the car with lots of harsh dishsoap and drying it, to remove dirt and some wax. Don't mind the amateur graffiti or the ugly front wheels...Les Schwab screwed up my alignment and it ate my nice Yokohomas up front. ![]() ![]() ![]() I then removed the bumpers, headlights, tail-lights, trunk lid, license plate bezel, and some other things. My front bumper is being replaced with a non-modified '95 bumper, and I'm getting rid of the fog lights. My license plate bezel and trunk lid are being replaced with parts from a '94 coupe as well, since they were both damaged in the horrible vandalism incident last June. ![]() The next step was to start sanding, so I applied grease and wax remover to the hood and front fenders and wetsanded those with 400 grit sandpaper. I called it a day after wetsanding the front end. -------------------- New Toyota project coming soon...
Day Two
Day two started with more cleaning with grease and wax remover, and then sanding some of the scratches from when my car was vandalized. I used 120, then 220, then 320, then 400 for these areas, except in a couple areas where the scratches are so deep that it'll be easier to use some body filler. ![]() I then sanded the roof and sides of the car, fuel door, all that fun stuff. I managed to get fiberglass embedded into my arm from my spot sanding pen, which wasn't much fun. ![]() ![]() ![]() Once the whole car was sanded (the stuff off the car still isn't sanded, except the trunk lid), I took a break and then worked on getting the TRD replica wing to fit. My new trunk lid has four holes in incorrect places that need to be filled, and needs four new holes for the wing. I drilled the new holes and laid fiberglass over the holes that are going to be filled from the bottom side of the trunk lid, and tomorrow will fill these holes in completely with body filler. I also fixed a small chip in a sideskirt caused by shipping, and filled the backside of the antenna hole with fiberglass cloth. From what I read, for a small area such as this, the fiberglass cloth should be fine and shouldn't crack and fall off. Again, this is another corner cut, where the best situation would've been to have sheet metal welded in there. ![]() At this point, it was late, and I'd been working for a good eight hours or so, so I called it a night. I'm debating whether or not to shave the sidemarkers. Now would be to opportune time to do it, but I'm not quite sure if I want to. What do you guys think? -------------------- New Toyota project coming soon...
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) ![]() |
Nice work Coomer, yeah if I were you I would shave the sidemarkers. Looks cleaner.
-------------------- JDM Powerplant installed, BPU coming very soon!
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '05 From torrance/carson, ca Currently Offline Reputation: 11 (100%) ![]() |
nice. good to know you're keeping your celica.
![]() Enthusiast ![]() ![]() ![]() Joined Feb 12, '06 From Fresno CA Currently Offline Reputation: 1 (100%) ![]() |
looking nice, hope everyhing comes out great
You have incredible skills Coomer, I vote get rid of the side markers.
oh yea 1988 called, they wanted their graffiti back ![]() -------------------- |
looks good so far chris, good to see you bringin back the yellow celi!
ditch the markers. =) -------------------- Former Team 5SFTE pro member ;)
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '04 From Illinois Currently Offline Reputation: 0 (0%) ![]() |
Keep up the good work Coom. Are you keeping her now?
(Laughs at Batman) -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 16, '02 From New York Currently Offline Reputation: 4 (100%) ![]() |
Nice work Coom!! I think u should ditch the side markers
![]() -------------------- Buy my Celica $2,500 - http://www.6gc.net/forums/index.php?showtopic=76562&st=0
![]() Enthusiast ![]() ![]() ![]() Joined Sep 23, '04 From Ohio Currently Offline Reputation: 4 (100%) ![]() |
good lookin coom.
new color? same color? mods? -------------------- ![]() |
I guess im outta the loop? Not selling ne more I'm presuming? Did you decide to go back to the cars natural hair color? Turquoise Pearl ftw.
aren't u going with that greenish color?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 7, '03 Currently Offline Reputation: 55 (100%) ![]() |
Nice work, can't wait to see it finished.
-------------------- JDM guy made me do it.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 20, '03 From Annapolis, Md Currently Offline Reputation: 5 (100%) ![]() |
About filling in the fender, do you think the fiberglass would hold? I was thinking the same thing, but thought the glass would pull and crack the bondo. whats your thought?
![]() Enthusiast ![]() ![]() ![]() Joined Feb 25, '03 From Springfield, MO Currently Offline Reputation: 1 (100%) ![]() |
as long as you fill thr outside of the holes with fiberglass before body filler you should be ok. make sure that the surrounding area is ground to bare metal of course
-------------------- Coming in 2010 full paintjob - new wheels - modified body - new interior - engine build- marriage |
QUOTE(b1gr3d @ May 28, 2006 - 10:25 PM) [snapback]438802[/snapback] as long as you fill thr outside of the holes with fiberglass before body filler you should be ok. make sure that the surrounding area is ground to bare metal of course Ground to bare metal would not matter, because Glass does not bond very well to metal.. I was thinking of drilling holes and then laying matt and resin |
QUOTE(dustinkemp @ May 28, 2006 - 8:44 AM) [snapback]438650[/snapback] good lookin coom. new color? same color? mods? Same color I think...not entirely sure yet. There will be some extra body parts and shaved stuff. ![]() QUOTE(Supersprynt @ May 28, 2006 - 8:47 AM) [snapback]438652[/snapback] I guess im outta the loop? Not selling ne more I'm presuming? Did you decide to go back to the cars natural hair color? Turquoise Pearl ftw. Yeah, I got lots of interest, but everyone kind of fell through, so I'm keeping it. QUOTE(Digndoug @ May 28, 2006 - 2:07 PM) [snapback]438652[/snapback] About filling in the fender, do you think the fiberglass would hold? I was thinking the same thing, but thought the glass would pull and crack the bondo. whats your thought? I'm going to fill mine with fiberglass...hopefully it'll hold up. ![]() -------------------- New Toyota project coming soon...
Day Three
Day three didn't consist of getting a whole lot done. I started by sanding some areas on the car where I'd missed before. I then sanded down the sidemarker area both on the outside and inside of the fender, taped it off so that resin wouldn't drip down, and applied two layers of fiberglass cloth and resin to the inside of the fender. ![]() ![]() ![]() I then put my efforts towards sanding the front bumper and rear license plate holder. It took me forever to sand down the front bumper! Once this was done, I glued a piece of plastic behind the key hole in the rear license plate panel. I'll fill the front with plastic body filler, and it should work perfectly to shave the plate hole. I used this technique on the Yelli Celi's rear plate panel after the car was vandalized, and it held up perfectly. ![]() ![]() I also began sanding down a sideskirt, but by this point my fingers were bleeding, so I called it a day. -------------------- New Toyota project coming soon...
damn... bleeding fingers. that's when you know you're working too hard. nice work coomer.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Feb 8, '06 From Nova Scotia, Canada Currently Offline Reputation: 1 (100%) ![]() |
Hey Coomer,
good luck and much success with the project. I had no idea you suffered such a vicious attack last summer! It's a wonder the Yelli Celi is still on the road. Many would have given up. I guess you are obsessed as the rest of us ![]() Again, hope all goes well and you have a chance to share your experience with the community. Ray. -------------------- ![]() |
Lo-Fi Version | Time is now: April 23rd, 2025 - 3:07 PM |
