> GT auto differential fluid
post May 29, 2006 - 10:44 AM
valerit1
Joined May 2, '06
From Nevada
Hi,
Witj considerable difficulties I got to my differential - %S-FE auto, behind the
transmission, "separate unit" only to discover it was almost empty! -
a quarter of a quart at best came out! Interstengly, I checked a couple
Camrys on junkyard and same - almost nothing in the diff.
The differential is dry, NO leaks outside. Now, what is between the trans and the diff -
even my factory manual does not say - they are joined together but listed
as a sepatate units. Anybody had this experience and any ideas?
Thanks!
post May 30, 2006 - 11:52 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE(valerit1 @ May 29, 2006 - 10:44 AM) [snapback]438938[/snapback]
Hi,
Thanks!
Yes they are seperate in the GT. You'll loose differential fluid whenever you remove your axels. ATF Dexron II or equivalent is recommended by the Toyota Service Tech Manual. Look here for more information:
http://www.celicatech.com/imagearchive/bgb...vicing%20at.pdf
Lo-Fi Version Time is now: February 20th, 2025 - 3:13 AM
