a friend has a GT and when it starts, the idle isn't as high as it should be, it just kinda bogs until it is warmed up.
I think it has to do with some elecrtical problems he's been having that makes me sad, I don't know. the question is, what sensor could be the problem ? thanks guys -------------------- |
![]() Enthusiast ![]() ![]() ![]() Joined Mar 29, '06 From Hull, UK Currently Offline Reputation: 0 (0%) ![]() |
maybe an injector problem?
should be cold starting to about 1500rpm dropping to about 800 when warmed up? I'm guessing somethings a bit blocked, or its not choking correctly so will be down on power and would struggle for power til its warmed up? Anyone else? |
check the resistance in the engine coolant temp sensor(s). if they're out of spec then replace.
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) ![]() |
QUOTE(Bitter @ May 30, 2006 - 7:58 PM) [snapback]439504[/snapback] check the resistance in the engine coolant temp sensor(s). if they're out of spec then replace. I agree. The sensor could be broken so the ECU thinks the car is up full temp all the time. -------------------- ![]() I will return one day. |
IAC valve dustin, make sure its clean
i vote coolant temp sensor. the one thats right on the motor, not the radiator one . should have a green harness plug.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Feb 8, '06 From Nova Scotia, Canada Currently Offline Reputation: 1 (100%) ![]() |
Wow!!
2 questions that don't need answers anymore, cool. i have a auto GT and it bogs down once in a while even when it's warm. idles at 400 rpm-- then dies, and kills the battery. needed to know the idle speed. is that 800 rpm for AT and MT? IAC valve and EGR problems give me a headache <-----------or is it because i just spent an hour researching this? anyway, off to bed! -------------------- ![]() |
Lo-Fi Version | Time is now: February 23rd, 2025 - 4:08 AM |
