> wheels shakes, on low speeds
post May 30, 2006 - 5:42 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
my car shakes when im goin from a dead stop to 20+ mph...after that its ok.....
also, when im going 55+ mph the car shakes bad.....like steering wheel shimmy......pretty bad....do u guys think hub rings will do the job? i have the 7g rims does it require hub rings?......any help would be great.....
post May 30, 2006 - 6:17 PM
No they dont need hub rings, I think you need to get your wheels balanced.
post May 30, 2006 - 8:17 PM
BLINKYxMUNKEY
Joined Nov 12, '03
From Crestview, Florida
QUOTE(DeW_H0e_GT @ May 30, 2006 - 6:42 PM) [snapback]439484[/snapback]
Hub rings wont fit since OEM wheels are made to fit snuggly on the hub.
FlickR
post May 30, 2006 - 8:20 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
ok thanx guys....i bought those hub rings for nuttin....stupid autozone dunno jack!!!!!....ask me to get some hub rings n get a wheel balance....Im not going to go back to autozone ANYMORE!!!!!
post May 30, 2006 - 10:33 PM
Starcraftjunkie
Joined Nov 21, '05
From Wpg, MB. Canada
well.. if you told them you had aftermarket rims, it's not exactly a bad recommendation... and they did tell you to get the alignment, which is most likely the cause.
post May 30, 2006 - 11:02 PM
celicast3sgte
Joined Jul 10, '05
From Monroe, WA
autozone is a good place for parts just dont ask their advice, i had a guy telling me that it was a beneficial upgrade to take the 2jz out of a lexus IS300 and put in a 7m-gte.... but then again i like their parts like HG and timing belts alot better!
post May 31, 2006 - 1:55 AM
vsideboy
Joined Mar 29, '06
From Hull, UK
Warped Brake Disc?
My rear was warped and it caused the whole car to shake around after the caliper had got hot and was sticking it. I stopped 3 times on the way to work once (20 miles) cos I thought a wheel was coming off.
post May 31, 2006 - 8:36 AM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
QUOTE(Starcraftjunkie @ May 30, 2006 - 10:33 PM) [snapback]439579[/snapback]
i did told him i have oem rims but it was for a 2000+ celica GTs...he says its a sport wheel...i need some hub rings.... kindasad.gif
i dont have anyproblems when stopping......does rotors affect driving when im pressing the gas pedal???..idk some1 gimme some clue
post May 31, 2006 - 9:26 AM
vsideboy
Joined Mar 29, '06
From Hull, UK
QUOTE(DeW_H0e_GT @ May 31, 2006 - 2:36 PM) [snapback]439684[/snapback]
I didn't have any trouble stopping, the trouble was that my nearside rear caliper was (and still is a bit) sticking, which after a while ended up warping the disc. From then on it would not affect anything when it was cold other than making an intermittent noise, but after a while it would heat up, the extreme heat would expand the brake fluid causing the piston to push the (piston side) pad onto the disc more, (causing more heat etc) and cos the disc was warped it would shake rattle and roll the car. But once I use the brake pedal it would go off cos both pads were tight on it rather than being on it tight in 1 place and not in another on the piston side.
I've since changed the discs and its not done it for since, however it is all getting a bit hot again so I might need to change the caliper as well if I can't free it off again.
Might not be anything to do with it mate, but its always something to check.
Get a Dial Test Indicator and stick the magnet to the strut, put a couple of nuts back onto the bolts so the disc is fastened to the hub and spin the disc by hand with the Dial lever touching the disc, it should only move the dial very slightly if at all. If it moves lots then either the disc is warped or its got something stuck behind it.
post Jun 1, 2006 - 5:44 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
turns out that my front tire was balder than sam jacksons head (in SHACK) biggrin.gif ...ive rotated the back tires which have liek 30% tread up front...and now the shakes dont happen anymore....didnt wanna go higher than 55+ mph because i have bald tires in the back.....hopefully i get some new tires soon....thankx for the info guys....
Lo-Fi Version Time is now: November 28th, 2024 - 2:37 AM
