> Brake Vibration, @ highway speed braking
post Jun 3, 2006 - 8:14 PM
Speedy2k
Joined Jan 6, '06
From Toronto, Canada
Recently I noticed that when braking from 100km/h (60mph) the car would shake and vibrate. I decided to check out the front rotors and pads. The rotors had quite a bit of thickness difference and were actually below the 23mm min thickness. So I got new rotors and pads.
I install the new rotors, pads and then go out to bed them in. I go on the highway and do some stops. My car is still vibrating! :x
I dont get it! What else could be wrong? The hub surface was clean and there looked to be no dirt or anything that could offset the mating surface with the rotor. Is it possible my wheel hubs are bent and have in/out play?
The car has new sway bar end links, ball joints, and tie rods that were all installed a couple of weeks ago. The driver side axle seems to be broken though, because it makes a noise every time I take off.
post Jun 3, 2006 - 8:40 PM
celica101
Joined Oct 6, '03
From Pittsburgh
My car did the same thing and oddly enough it turned out to be the wheel bearing. I replaced it and it was fine after that.
post Jun 3, 2006 - 9:42 PM
Speedy2k
Joined Jan 6, '06
Now how do I tell which wheel bearing is bad?
post Jun 3, 2006 - 9:49 PM
celica101
Joined Oct 6, '03
From Pittsburgh
if you jack up the front of the car grab the top of the tire and pull it towards you and push it back, if the wheel shakes the bearings going bad. Keep in mind this might not be whats wrong just happened to be the problem for me.
post Jun 3, 2006 - 10:44 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
shoulda research the probable causes before buying
post Jun 4, 2006 - 5:48 AM
Speedy2k
Joined Jan 6, '06
QUOTE(LewFX @ Jun 3, 2006 - 10:44 PM) [snapback]440819[/snapback]
post Jun 4, 2006 - 7:36 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
I had the same problem caused by hand brake (pakring brake). If you have been using it, that may be your problem too.
post Jun 4, 2006 - 8:01 AM
94GT
Joined Feb 25, '04
From Fairfield, CA
Do you have any uneven tire wear? That can cause vibration while decelerating through certain speeds.
post Jun 4, 2006 - 11:41 AM
Speedy2k
Joined Jan 6, '06
No this is strictly when breaking from higher speeds. It really vibrates. However yesterday I also noticed that when I am going 80mph I have the vibration in the steering wheel as well. I dont get it because I had all 4 wheels balanced???
Maybe the fact that my driver side axle has play at the tranny side is causing this vibration.
post Jun 4, 2006 - 11:45 AM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
try rotating your tires to see if you still have vibrations
post Jun 15, 2006 - 7:51 PM
Speedy2k
Joined Jan 6, '06
Rotated rear tires to the front and still have the same vibration. WTF!?!?
post Jun 15, 2006 - 8:39 PM
cheeco
Joined Jun 15, '06
From NJ
there alot of potholes around where you live? if so chances are you have bent wheels.
jack the car up and spin the wheel while looking at the inner rim edge, if it wobbles, its
bent. steel wheels will bend alot easier than alloy, but at the same time are easier to
bend back.
as for the brake vibration, you said you felt it in the car?, like the seat? could the rears be warped.
somtimes its hard to tell where the vibration is coming from unless you know the characteristics
of the car very well.
post Jun 16, 2006 - 11:13 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
it could be...
warped rotors
bent/warped hub
bent wheel
badly balanced wheel
missing axle dampener
the last 3 should cause vibrations when NOT braking and when braking, the 1st 2 are more likely to cause issues only when braking.
Lo-Fi Version Time is now: December 4th, 2024 - 11:32 AM
