Enthusiast Joined May 29, '06 From Tre 4 NC Currently Offline Reputation: -1 (0%) ![]() |
I have been shopping around for rotors and I come up on nice rotors but they are all specified for the gt is there really a difference if they are the same year in st and GT for rotors. for example could I buy ones specified gor gt and use them on my st?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Portsmouth, RI Currently Offline Reputation: 33 (100%) ![]() |
the front GT rotors are bigger than the front ST rotors and wont fit in the backplate.
i believe the rear GT rotors are the same size as the front ST...dont quote me on that one though -------------------- |
![]() Enthusiast ![]() ![]() ![]() Joined Mar 29, '06 From Hull, UK Currently Offline Reputation: 0 (0%) ![]() |
heres a uk site that list them all, click on them to get the dimensions.
http://www.speedways.co.uk/apec/list/toyot...-1994-1999.htm# |
![]() Enthusiast ![]() ![]() Joined Jan 3, '06 From The Netherlands Currently Offline Reputation: 6 (100%) ![]() |
QUOTE(vsideboy @ Jun 6, 2006 - 1:39 AM) [snapback]441545[/snapback] heres a uk site that list them all, click on them to get the dimensions. http://www.speedways.co.uk/apec/list/toyot...-1994-1999.htm# Sizes on this site seems good, but there's only missing one The size of the rotors on the GT SSII with super-strut: 283 mm -------------------- JDM ST205
Hmm, I've got a superstrutt GT and mine are the 275mm ones. Wierd!
You saying yours are different to that mate? |
Enthusiast ![]() ![]() ![]() Joined May 1, '03 From Michigan Currently Offline Reputation: 0 (0%) ![]() |
QUOTE the front GT rotors are bigger than the front ST rotors and wont fit in the backplate. The GT rotors will fit with the ST back plates, but you'll need to swap over to the GT calipers too. -------------------- Scott
West Michigan |
![]() Enthusiast ![]() Joined May 20, '06 From deltona, fl Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(scothaniel @ Jun 6, 2006 - 1:02 PM) [snapback]441683[/snapback] QUOTE the front GT rotors are bigger than the front ST rotors and wont fit in the backplate. The GT rotors will fit with the ST back plates, but you'll need to swap over to the GT calipers too. So just the rotor and caliper, i don't need the caliper mounting bracket? Steve -------------------- If Columbus was told, "use the search function," he would have learned that the World was flat.
QUOTE So just the rotor and caliper, i don't need the caliper mounting bracket? Correct - the hubs and brake lines are the same, so nothing else is needed. Except brakes pads. -------------------- Scott
West Michigan |
I'd have expected you to need the brakets too tbh, as the st discs are 255mm and the gt are 275mm, however, if you measure the gap between the edge of your current disc and the inside gap of the bracket then you'd know if theres 20mm gap then you can fit them in.
The GT calipers sit further out from the hub then the ST calipers to allow for the larger rotors - basically the bracket your expecting is built into the GT calipers.
I just did this swap about 2 months ago on my ST. -------------------- Scott
West Michigan |
OK, I was just thinking that because the calipers are in 2 pieces then people may just get the actual caliper piece and not the bracket. As I have never got a replacement caliper I didn't know what you get, but thinking about it cos the caliper is integral with the bracket then you should get both with the new ones. ok, everyones happy.
QUOTE(vsideboy @ Jun 6, 2006 - 8:20 AM) [snapback]441601[/snapback] Hmm, I've got a superstrutt GT and mine are the 275mm ones. Wierd! You saying yours are different to that mate? Yep, mine are 283 mm. Maybe because it's a european version -------------------- JDM ST205
![]() Enthusiast ![]() Joined Feb 19, '05 From leicester, England Currently Offline Reputation: 0 (0%) ![]() |
i did a full ST to GT swap UK cars and had to change the full wheel station to get the GT front disk in. the ST rear plate was just too small to house the GT disks.
have you any pics of swapping the GTs on to ST plates. Maybe its the US models are different. i also stripped a SSII (completely) and they are the same size as the GT ![]() Kev -------------------- Gen 6 Celica in Red with VVTI Beams engine, lowered 40mm, front and rear strut braces, asia tec 17 inch alloys, avon ZZ2 tyres, Rage Back box and a decat, JDM rear lights, red bits on the dash and clock shroud and a DVD player.
![]() Administrator ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '02 From Seattle, WA Currently Offline Reputation: 14 (100%) ![]() |
QUOTE(hurley97 @ Jun 5, 2006 - 1:55 PM) [snapback]441351[/snapback] the front GT rotors are bigger than the front ST rotors and wont fit in the backplate. i believe the rear GT rotors are the same size as the front ST...dont quote me on that one though They're not...the rear rotors are complete different to account for the e-brake. -------------------- New Toyota project coming soon...
QUOTE(celicaridinghot @ Jun 5, 2006 - 4:49 PM) [snapback]441344[/snapback] I have been shopping around for rotors and I come up on nice rotors but they are all specified for the gt is there really a difference if they are the same year in st and GT for rotors. for example could I buy ones specified gor gt and use them on my st? to answer the original question, no. you have to buy ST rotors for your ST -------------------- |
Lo-Fi Version | Time is now: February 17th, 2025 - 12:37 PM |
