3 Pages V  < 1 2 3 >
> adjustable cam gear for the 5sfe, anyone interested?
post Jun 9, 2006 - 5:17 PM
QUOTE(Bigmeanbulldog55 @ Jun 9, 2006 - 12:32 PM) [snapback]442948[/snapback]
With the exhaust being a slave cam, would I be able to adjust the single intake cam to maximize scavenging? I didn't really understand the reasoning behind ajusting the slave cam thing. If they were apart, you could delay the exhaust from closing. So distributer would adjust my spark and the cams adjust my fuel. Sounds like I would need at least a timing light if not a dyno run or 2 to maximize performance out of these things. I don't know how to go about it free hand, except for timing. Just adjust upward a small bit at a time.
cam timing is somthing you adjust on a dyno.
nuke from celicatech explained it pretty basicly like this :
basically you'll be able to tune the car like you would a single over had cam car... camshaft retard = more optimized for top end power, camshaft advance = more optimized for low end power
the timing light has nothing to do with cam timing.
post Jun 9, 2006 - 5:26 PM
kenjamatic
Joined May 20, '05
From sacramento, ca
hey presure cams for the 5sfe is a great idea...i'm in...just keep us updated with the post..
This post has been edited by kenjamatic: Jun 9, 2006 - 5:26 PM
post Jun 10, 2006 - 10:35 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
I personally think the best way to do true cam timing is to make adjustable slave gears. That's all I'm gonna say on that topic.
post Jun 11, 2006 - 7:05 AM
QUOTE(Kwanza26 @ Jun 10, 2006 - 11:35 PM) [snapback]443477[/snapback]
dont leave me hangin on a thread, bee.
post Jun 11, 2006 - 6:24 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(presure2 @ Jun 11, 2006 - 8:05 AM) [snapback]443557[/snapback]
To make the slave adjustable, you'd have to cut off the gear, extend it, and make a lock for it. It's very possible if you had a machine that could cut that deep into it, and even. I think it might be easier to get two slave cams, cut the gear off of one, and cut the center out of another. Get an engraving tool and mark a few degrees. You could elongate the gear so you could put a few locker pins in it to hold it in place. It would be some real work. I’m not sure it would be worth it. The signal is a good bit less work.
Live Free, Be Happy
post Jun 14, 2006 - 11:24 AM
frosty
Joined Sep 1, '04
From Alabama
you know, I wanted the ge head for control over both the intake and exhaust cams, but if you guys are devising a way to control the slave cam........ wink.gif
very nice.
CLOSED on 25 acres!
-shop coming soon....
post Jun 14, 2006 - 11:26 AM
pimped6gen
Joined Sep 16, '04
From Hershey, PA
in in...order me one!
post Jun 14, 2006 - 12:43 PM
celicak
Joined May 20, '06
From williamsburg, va
definately interrested. how difficult would this be for a novice? i mean i would have someone there to help me but just for a little guidance would i be able to do it myself? also would it be possable for a detailed install guide? i don't know how detailed that could be but just a thought.
post Jun 14, 2006 - 1:39 PM
QUOTE(celicak @ Jun 14, 2006 - 1:43 PM) [snapback]444553[/snapback]
installing one of these will include removing the timing belt.
so think of it as a timing belt job, plus 1.
not exactly a "easy" job, but with some help, and the BGB, its not that difficult.
also, i spoke with ken from ATS yesterday, and aaron will make as many as we need.
i believe the price will be the same.
so, everyone who is "interested" or "in" needs to find a spare cam gear, so that we'll have them to send to aaron to make them.
im prolly gonna have 2 made to start with, one for myself, and one for Dustin (batman722) so that we can do some testing, and see what we can get in Turbo and N/A form.
post Jun 14, 2006 - 3:50 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
ok...do we need one cam gear for them to make one..or a pair????
post Jun 14, 2006 - 3:53 PM
QUOTE(DeW_H0e_GT @ Jun 14, 2006 - 4:50 PM) [snapback]444624[/snapback]
since we only have one gear, we only need one.
however, if you dont want to disassemble your car and wait for ATS to do the work and send it back to you, you can get a 5th or 6th gen gear from the junkyard. they are the same.
post Jun 14, 2006 - 4:27 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Adjustable Cam on a False DOHC (2 camshaft, single cam driven) is really out of the question. You could only generate so much power before everything is wasted on that single belt driven cam. In a way, its great for simple boost/ bolt on power which is great for many people cause that route is the simplest way to go, but if you guys really want power do a 3s swap. At least It won't backfire down the road and you won't regret dishing out $$ on that 5s engine.
post Jun 14, 2006 - 5:29 PM
QUOTE(soulshadow @ Jun 14, 2006 - 5:27 PM) [snapback]444647[/snapback]
post Jun 14, 2006 - 7:16 PM
AllTrac96
Joined Jan 23, '05
From Portage
totally agreed. here we have a member going out of his way to get something made for us 5s guys and your shutting him down. kindasad.gif
post Jun 14, 2006 - 8:35 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
I think the install would be fairly easy, but tune would be a 3-4 on a 1-5 scale. I'm considdering this a good bit, but the tuning is what I'm worried about.
Manny, I'd like to wate to see what you guys can get out of a NA 5sfe, and the specs for tuning one. Man, if you could get a good esimate on NA hp, and a tuning guide, you could really go big with this idea. Well, as long as it's a good gain and actually tunable.
Live Free, Be Happy
post Jun 14, 2006 - 9:16 PM
QUOTE(Bigmeanbulldog55 @ Jun 14, 2006 - 9:35 PM) [snapback]444767[/snapback]
thats exactly what the plan is.
we'll be testing 2 of them to start with, one on my car and one on Dustins car.
we'll prolly try tuning dustins first, then mine.
once we do that, we will have solid before and after dynos, on back to back runs, with detailed info, so that there is no questions about what works and what doesnt.
post Jun 14, 2006 - 11:02 PM
BBoYRuGGeD
Joined Jun 4, '04
From Northern New Jersey
count another person in manny...not technically me but a friend of mine who has a 5th gen celica. when will all this go down? because me and my friend still have to pull the cam gear from my other friend's crashed 5th gen.
bboy
post Jun 15, 2006 - 11:25 AM
frosty
Joined Sep 1, '04
From Alabama
QUOTE(presure2 @ Jun 15, 2006 - 2:16 AM) [snapback]444786[/snapback]
CLOSED on 25 acres!
post Jun 16, 2006 - 3:38 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(presure2 @ Jun 11, 2006 - 12:05 PM) [snapback]443557[/snapback]
Nothin else to say really... cam gears are pretty subjective when it comes to making power. It's just a tuning tool after all... and what you get out of it is what you put in.
post Jun 19, 2006 - 12:52 PM
rzanology
Joined Apr 25, '05
From nyc
im a lil scared of the rough idle i keep hearing about....but im all for the extra power.
any updates presure? Im like a a fat kid standing outside the candy shop looking in! smile.gif
3 Pages V  < 1 2 3 >
Lo-Fi Version Time is now: December 2nd, 2024 - 1:18 AM
