Enthusiast Joined Oct 18, '05 From Waterloo/Oakville Currently Offline Reputation: 0 (0%) ![]() |
Hi, Im trying to remove the hubs from the front wheels.
i need to replace some of the studs. I have already taken my rotors and everything off. ive also taken the cod pin and hut off of the center bolt. what is my next step? -------------------- VitalMotion.net -- Sbonnick
"Dropped at Birth 6th Gen Celica" |
Enthusiast Joined Jun 3, '06 From Glasgow, VA Currently Offline Reputation: 0 (0%) ![]() |
They get pulled off with a slide hammer.
However you should not have to take them off to replace the studs. I did not when I did a couple of mine. Should be able to knock the old stud out the back with a hammer and then pull the new one in from the back. I think there are pictures of this in almost every sort of repair manual. Dan Kimber |
![]() Enthusiast ![]() ![]() Joined Aug 18, '04 From Silverdale, WA Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(DanKimber @ Jun 7, 2006 - 3:05 AM) [snapback]441914[/snapback] They get pulled off with a slide hammer. However you should not have to take them off to replace the studs. I did not when I did a couple of mine. Should be able to knock the old stud out the back with a hammer and then pull the new one in from the back. I think there are pictures of this in almost every sort of repair manual. Dan Kimber I had to replace two of my studs and did it all on the car just as you said. |
Lo-Fi Version | Time is now: February 18th, 2025 - 4:08 AM |
