> my gt4 has water problem
post Jun 7, 2006 - 8:23 AM
Ronnie5
Joined Mar 13, '06
[size=3][b]Can anyone help??,
I have a celica st185 gt4, Im am having problems with water staying in the engine/radiator when I drive it slow its fine but when I put my foot down and then stop wait a minute and switch off I have the contents of the radiator pour out through the expansion bottle which make the car overheat when I am driving it, I have changed the rad cap which makes no diffrence I can also hear the water flowing and bubbling inside engine
, once cap is off its as if the car breathes! water comes out and then goes back down over and over again until cool.
Can anyone help as I cant afford to take it to a garage!..
post Jun 7, 2006 - 8:40 AM
GMoney
Joined Jan 18, '06
From St.lucia
hey man i had same problem but try flushing out the radiator sometimes , silcone and rust gets blocks the fins in the radiator and create pressure build up when u turn off the car ..... jus try flushin the radiator
post Jun 7, 2006 - 9:02 AM
Whats your temperature sensor showing? You probably could use a thermostat.
post Jun 7, 2006 - 11:28 AM
Ronnie5
Joined Mar 13, '06
QUOTE(GMoney @ Jun 7, 2006 - 2:40 PM) [snapback]442043[/snapback]
I have flushed radiator out a month ago but i will try it again, thanks mate!! smile.gif
QUOTE(Supersprynt @ Jun 7, 2006 - 3:02 PM) [snapback]442046[/snapback]
The temp is showing normal then all of a sudden it goes into the red so then I take cap off top up and drive it 100 yards and it over heats again but could be thermostat or water pump? smile.gif
post Jun 7, 2006 - 12:24 PM
Could be either.
post Jun 9, 2006 - 3:45 AM
GT4WRC
Joined Mar 17, '05
From Auckland, New Zealand
Could be a HG failure.
Gary
1994 ST205 Celica GT-FOUR Group A WRC - running in new engine
1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come....
GT-Four spec list
post Jun 9, 2006 - 4:21 AM
Ronnie5
Joined Mar 13, '06
QUOTE(GT4WRC @ Jun 9, 2006 - 9:45 AM) [snapback]442875[/snapback]
Gary
No headgaskets fine mate Iv tested that Its somthing a little cheaper I hope!!
post Jun 9, 2006 - 10:09 PM
GT4WRC
Joined Mar 17, '05
QUOTE(Ronnie5 @ Jun 9, 2006 - 4:21 AM) [snapback]442881[/snapback]
How did you test it?
GT-Four spec list
post Jun 10, 2006 - 3:11 AM
Ronnie5
Joined Mar 13, '06
QUOTE(GT4WRC @ Jun 10, 2006 - 4:09 AM) [snapback]443185[/snapback]
my mate used something with a liquid which was a HG tester and was fine..
Lo-Fi Version Time is now: November 23rd, 2024 - 3:33 PM
