> SPEC Clutch Kit for the 3SGTE Swap, 3sgte swap using the 5sfe tranny
post Jun 7, 2006 - 10:41 AM
jcbass7
Joined Apr 20, '06
From Florida
I called Spec and ordered my clutch kit for the swap. They actually have a part number now for this set-up, the information is as follows:
Spec's tech phone number:
1-205-491-8581
I talked with Justin, who helped me out a ton, great guy to deal with.
his extension is 108
The part number for the clutch kit is:
ST6225S
The SECOND (2) in that part number is the number to reference what stage clutch you would like. I chose a stage two clutch, which i was told will hold 400 ft/lbs of torque.
If you wanted a stage 3 clutch the number would be as follows:
ST6235S
or a stage 1 (not recommended if you plan to add any power to the 3sgte) would be:
ST6215S
etc.
etc.
For reference this is what Lagos put together:
You need the
5fse - disk
5sfe - throwout bearing
5sfe - alignment tool
3sgte - pressure plate
3sgte - flywheel
The clutch kit includes all BUT the flywheel.
EDIT: The clutch kit they sell is basically a kit for the 3sgte that will bolt onto the 5sfe Tranny. It is the 3s disk with the 5s spline count smile.gif
For a ballpark figure, i paid 389$ for the stage two clutch kit and after shipping a total of 413$
This post has been edited by jcbass7: Jun 7, 2006 - 2:55 PM
post Jun 7, 2006 - 10:55 AM
you know, a better idea would be to call spec back, and get them to install the 5s spline onto a 3s disk.
that way, you get the full clamping power of the pp on the disk.
its very common, and very easy for them to do.
the 5s disk with the 3s PP is the old school.
post Jun 7, 2006 - 10:57 AM
jcbass7
Joined Apr 20, '06
From Florida
that might actually be what they do.. i am not totally sure. when i started mentioning what i was doing and hte parts i needed he told me there was a kit made. If Lago's is around he could tell us if they did that with the splines for him or not. If they did then im guessing that would be the same for this kit they have.
post Jun 7, 2006 - 10:59 AM
QUOTE(presure2 @ Jun 7, 2006 - 11:55 AM) [snapback]442072[/snapback]
yeah ask them if the disk is the 3sgte disk with the 5sfe spline count. thats what they did for my clutch. since they have a part number for it now, im sure they are doing the same thing for yours, but its good to doubble check.
the 5s disk is a little smaller then the 3s PP. so you dont get full surface contact. it dosnt really cause any issues, but its good to have it cover every inch of the PP if u can
post Jun 7, 2006 - 1:48 PM
SPEC01
Joined Jun 7, '06
From Birmingham, AL
Hey,
This is Justin from Spec. That is what we use. In the end it is actually the 3sgte kit with the hub from the 5S along with the tob and alignment tool. I am glad to help anyway i can so if anyone needs something please feel free to give me a shout..
Thanks,
Justin
Justin Ables
2490 Five Star Parkway
Bessemer, AL 35022
1.800.828.4379 Ext 108
justin@specclutch.com
www.specclutch.com
post Jun 7, 2006 - 2:19 PM
Justin, thank you for taking the time to join our community.
we have a member, his name is john horniack , installed IIRC a stage 2 setup from ya'll.
he had a problem with the disk seperating from the center section.
wondering if you can address what happen with this disk...and what if any precautions we should take while installing them.
post Jun 7, 2006 - 2:48 PM
BBoYRuGGeD
Joined Jun 4, '04
From Northern New Jersey
whats the price u paid on the stage 2 jc, if u dont mind me asking? smile.gif
bboy
post Jun 7, 2006 - 2:51 PM
jcbass7
Joined Apr 20, '06
From Florida
glad you found the site ok justin, thanks for the help with the kit.
(this could be a good reference thread for the swap section tongue.gif )
QUOTE(BBoYRuGGeD @ Jun 7, 2006 - 2:48 PM) [snapback]442167[/snapback]
bboy
i paid 389$ for the stage two before shipping and 413$ after shipping (ups ground)
This post has been edited by jcbass7: Jun 7, 2006 - 2:52 PM
SPEC01
Joined Jun 7, '06
From Birmingham, AL
Hey,
Have we taken care of it? If not has he contacted any of us directly? I didn't see any notes saying that he has had a return to us. If you can tell him to give us a call and get it taken care of. That is definitely a fluke issue.......everything else looks good except for the carrier not being connected..
Thanks,
Justin
Justin Ables
Bessemer, AL 35022
www.specclutch.com
post Jun 7, 2006 - 2:52 PM
BBoYRuGGeD
Joined Jun 4, '04
bboy
post Jun 7, 2006 - 2:56 PM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE(BBoYRuGGeD @ Jun 7, 2006 - 2:52 PM) [snapback]442171[/snapback]
bboy
post Jun 7, 2006 - 3:09 PM
justin. i have a small issue thats been bothering me for some time
i was one of the 1st guys to get this hybrid kit from you guys. i ended up with the stage 3 6puck clutch with a normal presure plate. ive had it for about a year now and the clutch seems to hold well and do its job. the only problem i have is that at idle, ill often hear a rattle that goes away when the clutch is pressed in. any ideas on what could cause this and if it could turn into a bigger issue later on? i also found a few posts on mr2oc about other spec users hearing the same rattle.
the fly wheel was resurfaced and everything was installed and broken in correctly, btw.
post Jun 7, 2006 - 3:20 PM
SPEC01
Joined Jun 7, '06
From Birmingham, AL
The rattling i think you are referring to is coming from TOB. That would make sense since you hear it go away when you depress the pedal. Now it shouldn't make for a larger problem so you should be fine. If it is really bothersome you can either go and buy a new TOB or we work something out if you call me. With it being almost over a year old i couldn't just send you one, but i am sure i can help you out to the best of my abilities. If you have any other questions feel free to give me a ring. I am here M-F 7-4 alabama time...(Not to sure thinks thats central)
Thanks,
Justin
Justin Ables
Bessemer, AL 35022
www.specclutch.com
post Jun 7, 2006 - 3:52 PM
QUOTE(SPEC01 @ Jun 7, 2006 - 3:51 PM) [snapback]442170[/snapback]
Hey,
Thanks,
Justin
justin,
i believe he has been in contact with you guys, and has sent it back.
as far as i know, he's waiting on the return.
post Jun 7, 2006 - 5:39 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
Thank you!!!!!!
post Jun 8, 2006 - 7:21 AM
SPEC01
Joined Jun 7, '06
From Birmingham, AL
His disk is actually on the way back to him. It left here on the 6th. We got it fixed for him.
Justin Ables
Bessemer, AL 35022
www.specclutch.com
post Jun 8, 2006 - 7:42 AM
QUOTE(SPEC01 @ Jun 8, 2006 - 8:21 AM) [snapback]442521[/snapback]
AWESOME.
thanks for the update.
as a sidenote, do you make a lightend flywheel for the 5sfe? cost?
if so, could you possibly post a pic or 2? (if you need it hosted, PM the pic to me, ill host it)
also, can you give me your recommendation on a setup for my car, its a 94 GT (5sfe) thats turboed, im putting ~275ft lbs to the wheels, and about 235whp, the goal for the car is 250whp.
im looking for the lightest pedal feel i can get, while still holding the power of course. wink.gif
post Jun 8, 2006 - 9:01 AM
SPEC01
Joined Jun 7, '06
From Birmingham, AL
Yes there is a lightened flywheel. Part # ST09A Price is $419. Weight is roughly about 10lbs. It is aluminum and that is the only flywheel we offer for 5SFE motor. As for the clutch I think you would be best in a 2+ holds 305 flywheel torque( part # ST733H). Great daily driver clutch and great peddle pressure. As far as the pics the flywheels all pretty much look the same. You can see what they look like at www.specclutch.com just go to the products section and check out flywheels.
Thanks,
Justin
Justin Ables
Bessemer, AL 35022
www.specclutch.com
post Jun 8, 2006 - 9:14 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
Justin,
Thanks for joining our site, I give you much respect for taking the time. I'm running a spec stage 3 clutch with my setup. Almost 10,000 miles not one problem (knock on wood), I am very happy with my kit. The next time I replace the clutch, I'll be calling your company again.
Thanks again
I will return one day.
post Jun 23, 2006 - 11:27 AM
SPEC01
Joined Jun 7, '06
From Birmingham, AL
Thanks again guys for the warm welcome a your business as well. I am here to help you guys anyway i can, and i am always a phone call away. So if you have any problems please give me a shout...
Thanks,
Justin
Justin Ables
Bessemer, AL 35022
www.specclutch.com
Lo-Fi Version Time is now: November 30th, 2024 - 1:37 AM
