Ross Piston Set and Camshaft, how much psi can it handle? |
Jun 11, 2003 - 11:11 PM |
Enthusiast Joined Feb 9, '03 From St Paul MN Currently Offline Reputation: 0 (0%) |
if i change my piston to after market piston and also the camshaft..how much boost of psi can the engine handle? im just carious cause i asked some GTS club up here and they say it might handle to 10-12 psi of boost. anyone might know?
Jun 11, 2003 - 11:36 PM |
Enthusiast Joined Oct 1, '02 From North Bethesda, MD Currently Offline Reputation: 0 (0%) |
camshafts have nothing to do with how much boost you can take.
pistons will help, i haven't heard of the specific ones you are talking about... but if you are going to go higer than 8 psi, forged rods would be a very good idea, otherwise you'll be in danger of throwing one. always better to spend the 800 now and not potentially put a rod through the block (and potentially the turbo) later on when you get boost happy... unless you can hold yourself to 8 psi, get rods. -------------------- 1994 Lexus ES300
1989 Supra Turbo 1990 RHD ST185RC - JDM Spec |
Jun 12, 2003 - 2:38 AM |
Enthusiast Joined Oct 1, '02 From Minnesota, USA Currently Offline Reputation: 0 (0%) |
Well, when you start talking HP gains...of course you're going to need to upgrade your cams...especially after the 250 mark. Pistons will help...anything to lower your compression will help. Get a metal head gasket fo sho cuz that will help out a bunch. Just replace as many seals as you can to make sure the engine is in top shape. I've seen people with just new pistons, piston rings, metal head gasket, camshaft regrinds with 5sfte runnin 15-20psi.
-------------------- 95 Toyota Celica GT
Jun 12, 2003 - 5:57 PM |
well you don't NEED to upgrade your cams. it's a good idea, but i was saying that AM cams will not allow you to run more boost. they have nothing to do with it... it's all the pistons, rings, rods, and crank. if you run 15-20 psi on stock 5sfe rods you will throw them. i can guarantee this. spend the 800 and get custom forged ones. it will let you sleep at nite, and if you are going to crack open the block to build the inside, you might as well put in as much as you can. if you won't shell out for that, at least get them race prepped and shotpeened, and that will help strengthen them up. This post has been edited by Charlie97L: Jun 12, 2003 - 5:58 PM -------------------- 1994 Lexus ES300
Jun 12, 2003 - 8:40 PM |
I meant to say rods with my list up there lol.
And yeah, I know. But when you start running 15-20psi...your engine is running a lot harder...more hp = more stress on engine...which means u should upgrade cams to be safe. -------------------- 95 Toyota Celica GT
Jun 12, 2003 - 11:01 PM |
Enthusiast Joined Feb 11, '03 From Phila, PA Currently Offline Reputation: 0 (0%) |
Get some TRD stickers, they add like 15hp and increase engine reliability 10 fold.
Jun 21, 2003 - 3:09 PM |
Enthusiast Joined Jun 13, '03 From brooksville,fl Currently Offline Reputation: 0 (0%) |
where can i get cams for my 7afe
Jun 21, 2003 - 9:07 PM |
Enthusiast Joined Jan 9, '03 From St. Louis Currently Offline Reputation: 0 (0%) |
you should just gank the metal composite off or a 98+ camry for a metal head gasket
-------------------- [img]http://photos-081.facebook.com/n6/081/n15913038_30266081_3342.jpg[/img]
Lo-Fi Version | Time is now: November 29th, 2024 - 4:29 AM |
