remove that @#$@ing cigarete lighter, how ? |
Jun 11, 2006 - 11:44 PM |
Enthusiast Joined Mar 25, '06 Currently Offline Reputation: 0 (0%) |
So im painting a few of my parts and i cant seem to remove the cigarette lighter ? am i missing some vital information ?
-------------------- ----- '94 ST hatch --- Yellow ----- |
Jun 11, 2006 - 11:48 PM |
Enthusiast Joined Oct 11, '05 From Ajax, Ontario Currently Offline Reputation: 2 (100%) |
after about an hour brutal frustration i just decided to tape it off and paint around it
Jun 12, 2006 - 12:12 AM |
Enthusiast Joined Oct 12, '05 From Texas Currently Offline Reputation: 59 (100%) |
This is going to be a funny topic!
~snap -------------------- Past: V6 Swapped 6G Celica, E46 BMW M3, Jeep Wrangler TJ
Current: 850rwhp C6 Corvette Grandsport, Gen1 6.2L Ford Raptor |
Enthusiast Joined Aug 23, '05 From Princeton, Minnesota Currently Offline Reputation: 7 (100%) |
lol i cant get mine to stay together
-------------------- -Brian
Jun 12, 2006 - 12:16 AM |
i know it can be done! Look at this picture from djultimate car
Jun 12, 2006 - 2:33 AM |
Enthusiast Joined Nov 13, '02 From So Cal Currently Offline Reputation: 3 (100%) |
look harder. its not difficult. it will come apart...
Jun 12, 2006 - 5:41 AM |
Enthusiast Joined Mar 29, '06 From Hull, UK Currently Offline Reputation: 0 (0%) |
1 clip on the metal part of it, slots into the plastic part of it. You need to get a screwdriver and hold in the metal part so that you can slide the metal part out first, then the plastic part will come out too. Pain in the neck, my girlfriends corsa lighter is even harder though, I almost stabbed a screwdriver through my hand trying to prise hers out, couldn't get it so had to break it apart to get it out.
Jun 12, 2006 - 6:48 AM |
Enthusiast Joined May 5, '05 From New-Brunswick Canada Currently Offline Reputation: 3 (100%) |
take out the light by rotating it 1/4 turn or so and pulling it out, take the black plastic cover off (comes off really easy).
push the metal part out, this requires a little wiggling and some force. Afterwards just unclip the rest of the parts -------------------- ----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy |
Jun 12, 2006 - 11:28 AM |
Enthusiast Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
I had to break the plastic part i believe.
so now I have this: -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Jun 12, 2006 - 2:18 PM |
Enthusiast Joined Dec 16, '02 From New York Currently Offline Reputation: 4 (100%) |
^ Just out of curiosity… do those buttons do anything?
-------------------- Buy my Celica $2,500 - http://www.6gc.net/forums/index.php?showtopic=76562&st=0
Jun 12, 2006 - 6:59 PM |
Enthusiast Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) |
They probably have to do with his air ride compressor
Jun 13, 2006 - 11:08 PM |
the little round ones are air ride - reds (front up - back up) and black is (front down - back down) The 3 toggles are (Amp - Compressor - power antenna)
Jun 16, 2006 - 1:55 AM |
Enthusiast Joined Jun 14, '06 From bainbridge ga Currently Offline Reputation: 2 (100%) |
QUOTE(phonex98 @ Jun 11, 2006 - 11:44 PM) [snapback]443804[/snapback] So im painting a few of my parts and i cant seem to remove the cigarette lighter ? am i missing some vital information ? hey if you break it i got a good one cheap and i'll send intsructions |
Nov 15, 2006 - 12:47 PM |
anyone have any pics? I was looking at it yesterday and I couldn't figure it out..
Thanks! -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Nov 15, 2006 - 1:18 PM |
I did this the other day to switch my shifter surround. it was a little tricky but I go it. I'll do it again and take some pics if you guys really want
Nov 15, 2006 - 3:25 PM |
<~~~ Really wants
Nov 16, 2006 - 12:59 AM |
OK. I took some overly detailed pictures for you here goes...
Taking the Cigarette Lighter OUT Pull the shifter surround out and unclip the shift boot. then you see this unplug the cigarette lighter unplug the light by twisting it then pulling it out then you are left with this the black piece comes off fairly easily the two pieces to it will probably come apart, don't worry about it then you should have this just push the lighter assembly out from the back and you now have this now just pop out the other plastic piece pushing out from the back again and its out. congrats now the fun part Putting the Cigarette Lighter Back IN take the piece in the last pic above and match the tab to the indentation in the shifter surround and push it in on the cigarette lighter itself there are two tabs, a smaller one and a bigger one. they match up to the grooves in the plastic piece you just put in line them up and snap it right in again you are left with this. everything should line up perfectly on this side now (more little tabs and grooves) put the two black pieces back together and slide them on. they might not snap in and stay in place, thats fine, when you put the LED back in it will hold it then just plug everything back in the way you took it off and Congratulations you are now back where you started -------------------- |
Nov 16, 2006 - 11:32 AM |
Wow... haha.. brought my thread back from the dead! I was just looking at "Read new posts" and i saw my name ... i was confused, because i didnt remember making this post, and BAM, ive got a crazy howto Well, thanks hurley.. that is super detailed
Nov 16, 2006 - 12:33 PM |
Thank you so much!! hurley97 you are amazing!!
Jan 12, 2021 - 8:27 PM |
Enthusiast Joined Jun 30, '17 From Maine, USA Currently Offline Reputation: 0 (0%) |
Thanks for this.
I found an extension for Chrome web browser that removes the horrible Photobucket watermark across the center of each image. https://chrome.google.com/webstore/detail/p...g/related?hl=en I'm not personally affilated, but I really like it. If you see the terrible Photobucket watermark across the center of each image, try this extension. w00t Craig |
Lo-Fi Version | Time is now: November 29th, 2024 - 7:17 AM |
