> A'PEXi S-AFC and A/F gauge installation., I'm still a little confused...
post Jun 12, 2003 - 3:38 AM
Delta_Phoenix
Joined Oct 16, '02
From Hohenwald, Tennessee
I know that someone posted a how-to on this, but I've heard a different way to wire it up. The how-to that's listed says that the ECU is behind the glovebox. I talked to SpedToe169, who also has the S-AFC, and he said the ECU is behind the center console. Can anyone confirm where the ECU is?
Now about the air/fuel gauge installation...
I read a previous post about where to hook up the A/F gauge but it was never really made clear which wire to splice into. Can someone help me out with this one?
post Jun 12, 2003 - 12:13 PM
Mynzeyes
From Franklin/Nashville, TN
the ECU is behind the center dash, down under the CD player and all that, basically on the floor. if you get in the pass. side floorboard, and pull the carpet up in the center, you will see it. as far as the air/fuel ratio gauge, it plugs into an o2 sensor, but i'm not sure if it's the upstream or downstream sensor...when you get it, it'll have directions, or check out the how-to, but iono if that tells you which to wire it to or not. also, if you can find a pin-out, you could hook it up right near the ECU w/ the AFC smile.gif. either way, i'll come help yah tongue.gif
-John-
AIM==Mynzeyes
post Jun 12, 2003 - 2:35 PM
Delta_Phoenix
Joined Oct 16, '02
post Jun 12, 2003 - 3:53 PM
94celicaguy
Joined Nov 11, '02
just splice the o2 wire off of the gauge into the o2 sensor on your exhaust manifold.
post Jun 12, 2003 - 8:42 PM
snadman
From Minnesota, USA
Yeah, but don't do it before the ECU connected. Splice into iot after the little plastuc lug piece which is about 6 inches up the wire. You wanna do it on the Main O2 sensor which is the top one...the first one the exhaust will hit...there's another one about a foot further down but don't use that one...not accurate readings.
95 Toyota Celica GT
Dead for now --> Soon to have a 3S-GTE
02 WRX --> This is for speed
- Borla Exhaust
- TurboXS BOV
- Custom CAI
02 Civic EX
- MB Quart Reference 5.25" Components
- Rockford MTX 8" Subs in the doors
- Alpine Type S Rear Fills
- 2x Alpine SWR-1042D Subs in a custom fiberglass box
- Alpine F345 Amp for the front doors
- Alpine M605 on each Type R
- Phoenix Gold wiring
- Alpine CDA-9855 Head Unit
- Alpine Amp link
- 2x Rockford Fosgate 1 Farad Caps
- The best Viper 791 alarm install ever
post Jun 19, 2003 - 4:44 AM
Delta_Phoenix
Joined Oct 16, '02
I'd like to keep all of my wires out from under the hood if possible. Doesn't the O2 wire from the air/fuel gauge wire into the same wire the AFC does?
Also, the gauge I bought requires a 5 amp/12V power source. There are no 5 amp fuses in our cars so what do I run the hotwire to? I'm pretty sure that it HAS to be wired into something that's run by a 5 amp fuse, because my friend and I are currently trying to install the same type of gauge in his car and wiring into the cig. lighter doesn't work (run by a 15 amp fuse). The fuse pops every time we try that. We're going to wire into the gauges tomorrow since his are run by a 5 amp fuse and see what happens.
Lo-Fi Version Time is now: November 28th, 2024 - 8:26 PM
