> just threw in the custom clears!
post Jun 12, 2006 - 8:03 PM
Theyellowdart084
Joined Jun 14, '04
From Buffalo, NY
Edit: ok i resized the pics...sorry again...
After:
Before:
This post has been edited by Theyellowdart084: Jun 12, 2006 - 8:18 PM
post Jun 12, 2006 - 8:11 PM
phonex98
Joined Mar 25, '06
ahh! get a resize... i cant even use my imagination to compare them at that size.
----- '94 ST hatch --- Yellow -----
post Jun 12, 2006 - 8:16 PM
Theyellowdart084
Joined Jun 14, '04
From Buffalo, NY
thanks...i just edited it....that last pic was MASSIVE haha....
post Jun 12, 2006 - 10:26 PM
snapshotgt
Joined Oct 12, '05
From Texas
very nice, how did you make them look so good? ...did you make them? HOW!!??!! lol...
~snap
post Jun 13, 2006 - 9:21 AM
Theyellowdart084
Joined Jun 14, '04
From Buffalo, NY
thanks for the compliment biggrin.gif ....i can't really take all the credit on this one, i bought them from celiracer....i PMed him a while ago and asked him how he did it and this is what he said:
Hey man. There is a how-to on the forum. But i kinda did a little bit different. First things first i'll try to follow you through it step by step.
Things you need.
1. oven
2. fillips screw driver
3. pan
4. freezer
I KNOW I KNOW sounds kinda funny. But it works.
take the bulbs out of the turns and out of the bumper.
turn your oven on 450 degrees.
get a pan and place one turn signal onto the pan. Then put the pan in the oven.
(NOTE) you want to watch the turn signal as its in the oven.
I also don't know how long to keep it in there. But just remember this.
(the glue around the housing melts faster then the actual plastic turn signal does)
4. once you think the glue is melted enough pry the clear lense off the plastic housing. then take a screw driver and take the orange block out of the housing. If you hurry you can just throw the clear lense back into the housing and throw it into the freezer so the glue can tighten back up. If it doesn't work that easy then put the housing back into the oven so the glue can heat up again. After that is done do the same thing to the other turn signal.
post Jun 13, 2006 - 4:53 PM
celiracer
Joined Oct 5, '05
From NE
Looks good man. now you need to take a picture of your full car so you can see how good it looks with the rest of the car wink.gif
Lo-Fi Version Time is now: December 4th, 2024 - 4:37 PM
