3 Pages V   1 2 3 >
> Installation of injen intake
post Jun 14, 2006 - 11:16 PM
6strngs
Joined May 12, '06
From Wilmington, NC
I feel kind of stupid asking this actually. But when trying to install it, I notice one hole, and two nipple things. (for lack of a better word tongue.gif ) now, there is a rubber hose that obviously connects to one of them, and the other sensor plugs into the hole. but I don't know what the other nipple thing is for... the intake came with a 6"-ish long rubber hose that fits over the nipple but I don't know where the other end of that hose is supposed to connect to...
post Jun 14, 2006 - 11:39 PM
ZacMan1987
Joined Jan 6, '06
The hose that goes from the crank case to the intake tube is the most important. It preserves vaccum in that area. If you want to, you can get an oil catch reservor to go inbetween, and it will catch any water and such as it recirculates that air.
http://www.nfauto.co.uk/oil_catch_tank.htm
A link to what this actually looks like. In extreme turns such as autocrossing, these can actually be necessary, as cars like the 350Z have reported oil splash being sucked into the intake and run through the combustion cycle.
For practical purposes and the time being, run the hose from the crank case to the intake tube, and tie the other one somewhere out of the way to either be left there, or used when you pick up an oil catch tank.
post Jun 14, 2006 - 11:59 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(ZacMan1987 @ Jun 14, 2006 - 9:39 PM) [snapback]444859[/snapback]
do you have any pictures? is the hose from the crank case the one that comes from somewhere deep down and plugs onto the nipple thingy that's closer to the throttle body? if so, I've already got that one on...
post Jun 15, 2006 - 1:08 AM
6strngs
Joined May 12, '06
From Wilmington, NC
Okay, here's the deal, I found a picture of the injen intake posted by another member of this board. I drew some red arrows pointing to the hose I'm talking about. I see it connects onto the engine... but my car already has a hose there that connects near the throttle body... what would I do with that hose then?
EDIT: stupid bandwith limitations... here's the image again
This post has been edited by 6strngs: Jun 15, 2006 - 1:38 AM
post Jun 15, 2006 - 8:19 AM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
that pic looks like mine a long time ago. o snap it is! ahhh the o injen, sniff sniff
This post has been edited by LewFX: Jun 15, 2006 - 8:20 AM
post Jun 15, 2006 - 11:51 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(LewFX @ Jun 15, 2006 - 6:19 AM) [snapback]444938[/snapback]
yeah it is, sorry, but can you tell me where the hose connects? I mean, I see where it connects now, but on my car there already is a hose right there that connects near the throttle body.
post Jun 15, 2006 - 1:26 PM
LewFX
Joined Jan 28, '05
follow the picture! the bigger hose goes from valve to intake, take that hose already connecting and put the other end on the intake.
post Jun 15, 2006 - 1:28 PM
Toyoca
Joined Mar 14, '06
From Mary Land
i think the intake in my ST has only the o2 sensor connected to it is that bad?!
post Jun 15, 2006 - 2:44 PM
ZacMan1987
Joined Jan 6, '06
oh snap. I see now. Mine only had 1 nipple on it.
Yeah. The one closer to the filter end of the intake should be attached to the crank case as pictured, and the one which goes way down towards the back of the block should be attached higher up, towards the TB end of the pipe.
Toyoca
And yeah, if you only have ur O2 sensor plugged in, I'd go ahead and attach the other hoses. A little vaccum is definitely not a bad thing.
post Jun 15, 2006 - 3:17 PM
Toyoca
Joined Mar 14, '06
From Mary Land
QUOTE(ZacMan1987 @ Jun 15, 2006 - 3:44 PM) [snapback]445048[/snapback]
Toyoca
theres another hose?
post Jun 15, 2006 - 3:23 PM
LewFX
Joined Jan 28, '05
theres 2 nipples and a sensor hole on the injen
post Jun 15, 2006 - 3:57 PM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
QUOTE(ZacMan1987 @ Jun 15, 2006 - 12:44 PM) [snapback]445048[/snapback]
Toyoca
There is no O2 sensor on any intake, o2 sensors are on the exhaust. st cias only have 1 hole for the air intake temperature sensor. gt intakes have a line that runs to vac also.
post Jun 15, 2006 - 7:32 PM
Toyoca
Joined Mar 14, '06
From Mary Land
QUOTE(CheesyLobster @ Jun 15, 2006 - 4:57 PM) [snapback]445079[/snapback]
Toyoca
k i c. does it matter that the other hole on my intake is open? (its custom) should i close it?
post Jun 15, 2006 - 7:43 PM
Projektminisupra
Joined Apr 6, '06
From Willington, CT
[/quote]
yeah ya should. the reason theres a filter there is so that junk wont pulled into the intake manifold. having a hole kinda defeats the purpose wink.gif
This post has been edited by Projektminisupra: Jun 15, 2006 - 8:06 PM
Mini Supra... in need of mini boost.
post Jun 15, 2006 - 8:28 PM
Toyoca
Joined Mar 14, '06
From Mary Land
[quote name='Projektminisupra' date='Jun 15, 2006 - 8:43 PM' post='445149']
[/quote]
[/quote]
k. how do i close it lol
post Jun 15, 2006 - 11:17 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(LewFX @ Jun 15, 2006 - 1:23 PM) [snapback]445068[/snapback]
exactly! so I plug the sensor into the hole, then I plug that rubber hose from one nipple to the crank case, and then the other hose that comes from inside somewhere connects to the other nipple... so the other hose that connects to the throttle body doesn't have anywhere else left to connect to on the intake...
post Jun 16, 2006 - 7:14 AM
Toyoca
Joined Mar 14, '06
From Mary Land
dont mean to thread jack but anyone know what i can plug up the extra hole with
post Jun 16, 2006 - 8:41 AM
LewFX
Joined Jan 28, '05
there should not be an extra hole! unless u drilled a new one for no reason
post Jun 16, 2006 - 12:58 PM
Toyoca
Joined Mar 14, '06
From Mary Land
QUOTE(LewFX @ Jun 16, 2006 - 9:41 AM) [snapback]445309[/snapback]
or...i got a civic intake and modified it lol. so there is an extra hole. how should i plug it up? you think it damaged anything? i figure there shouldnt be too much suction there
post Jun 16, 2006 - 1:18 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(Toyoca @ Jun 16, 2006 - 10:58 AM) [snapback]445372[/snapback]
easiest way would be to wrap it in duct-tape... but that looks very unprofessional, lol. I suppose if you wanted it to look great you could take it to a welding shop and have them cut out a same-size circle and weld it in for you. could be costly though.
3 Pages V   1 2 3 >
Lo-Fi Version Time is now: November 27th, 2024 - 10:12 AM
