Enthusiast Joined Mar 22, '03 From NH, USA Currently Offline Reputation: 0 (0%) ![]() |
Does anybody know where I could get one of those "Add-A-Circuit" piggyback fuse things for wiring my indiglo gauges to the parking light fuse?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 13, '02 From So Cal Currently Offline Reputation: 3 (100%) ![]() |
i kno pep boys and autozone have em
Thats good to hear both of those are near here, would you happen to know the part number for the one used with the parking light fuse?
"Add-A-Circuit" wire/fuse add on extension(#0FHM0200ZP)
Enthusiast Joined Oct 4, '02 Currently Offline Reputation: 0 (0%) ![]() |
Those "add-a-circuit" things are great. Make sure you check the amps of the fuse you're plugging into. The LittelFuse brand "add-a-circuit" I saw at Autozone is safe up till 10amps(total). So don't plug it into anything higher. It may still work, but you risk catching on fire.
Thanks comrade, I'll go check it out this weekend.
OR YOU CAN JUST PLUG THE POWER WIRE INTO THE DASH PANEL FUSE ON THE FUSE PANEL SO WHEN YOUR TURN ON YOUR LIGHTS THE INDIGLOS WILL TURN ON TOO....
Enthusiast ![]() ![]() ![]() Joined Mar 4, '03 Currently Offline Reputation: 0 (0%) ![]() |
OR YOU CAN JUST SHOUT AT EVERYBODY....
Lo-Fi Version | Time is now: February 17th, 2025 - 6:47 PM |
