> 205WHP @ 6psi
post Jun 20, 2006 - 11:42 PM
nemesis
Joined Jan 14, '06
I just wanted to announce that my car did produce 205WHP @ 6psi. I have to retune on 15psi, which we would probably bring me to 300WHP.
Just thought that I would share this with my fellow 6GC members.
Please give your input!
nemesis
I drive a Celica. Anything "less" is just a car!
post Jun 20, 2006 - 11:51 PM
how did you manage to run 6psi?
what turbo are you using?
This post has been edited by lagos: Jun 20, 2006 - 11:52 PM
post Jun 20, 2006 - 11:52 PM
j0e_p3t
Joined Dec 8, '05
From torrance/carson, ca
dyno sheet?!
post Jun 20, 2006 - 11:53 PM
nemesis
Joined Jan 14, '06
I did not have a boost controller to turn up the boost. So to be safe they tuned my car at 6psi.
post Jun 20, 2006 - 11:57 PM
nemesis
Joined Jan 14, '06
I did not bother get the dyno sheet since I will be retuning on just 4 days.
I wil post the latter.
post Jun 20, 2006 - 11:58 PM
j0e_p3t
Joined Dec 8, '05
then i 'll come back to this thread in 4 days. can't wait to see what numbers you get with higher boost.
post Jun 21, 2006 - 1:18 AM
tim86
Joined Oct 31, '03
From Orlando, Florida
congrats... u have a real nice celica by the way
post Jun 21, 2006 - 1:20 AM
WH95TE
Joined Jun 16, '06
From Plantation, FL
I'll be back in 4 days, i'd like to see it
post Jun 21, 2006 - 1:45 AM
"this thread is worthless without pics"
that and wat motor...what turbo... ect ect
post Jun 21, 2006 - 1:56 AM
WH95TE
Joined Jun 16, '06
From Plantation, FL
QUOTE(playr158 @ Jun 21, 2006 - 1:45 AM) [snapback]447041[/snapback]
Performance Modifications
3SGTE Swap
Manual Transmission Swap
Front Mount Intercooler
Haltec Stand Alone Computer
MSD Ignition
MSD Spark plug Wires
NGK Spark Plugs
Turbo Smart BOV
Turbo XS Manual Boost Controller
HKS Cam Shafts (272)
HKS Cam Gears
550cc Injectors w/Custom Fuel Rail From An MR2
Fuel Pressure Regulator w/gauge
Walbro Fuel Pump (255)
TRD Air Filter
HKS Exhaust w/Custom 3" Catback
Optima Battery (Red)
post Jun 21, 2006 - 3:27 AM
Glitch001
Joined May 8, '06
From Irvine
Still on the stock ct26? or a 20b?
Also, why the 272/272 cams, wouldnt the 264s return lower end torque?
Cant wait to see some picts
post Jun 21, 2006 - 9:19 AM
jgreening
Joined Jan 17, '04
From Illinois
What turbo?
post Jun 21, 2006 - 8:44 PM
burneeed
Joined Dec 18, '05
From BANNED
hrmmm 300whp out of what turbo? 550cc Injectors from an mr2 turbo? Good luck with 300whp on a ct26...... or is it a third gen? Honestly man Need pics!
BANNED!
post Jun 21, 2006 - 8:47 PM
Glitch001
Joined May 8, '06
From Irvine
a ct20b COULD do it, a ct26 wont. It will run out of breath, the injectors are going to be stressed to the max as well. Not to seem rude, but a 9psi increase will not give you 95whp. And if you do crank it that high, your putting a lot of strain on the turbo and injectors. Also at what rpm did your peak happen, with a front mount on a small turbo like the ct26 im assuming would cause crazy lag. What clutch did you choose to go with? Also not to debate the small stuff, you keep saying you didnt have a boost controller but listed in your mods is a Turbo XS MBC?
Say no to pea-shooter turbos.
This post has been edited by Glitch001: Jun 21, 2006 - 8:53 PM
post Jun 21, 2006 - 9:00 PM
nemesis
Joined Jan 14, '06
I will post some pics b4 the weekend is up! I am running a CT26 stock turbo, 3SGTE Motor with the all-trac tranny...I upgraded cams shafts, cam gears, injectors and fuel pump--all of which contributed to 205WHP at only 6psi.
I'll keep you all posted!
post Jun 21, 2006 - 9:07 PM
Glitch001
Joined May 8, '06
From Irvine
When you did your cams, did you do a shimless bucket conversion or os valves with springs? 15psi on a ct26 is a lot, but if its what you want I wish you the best of luck. Especially on a stock transmission (or im mistaken you said all-trac tranny meaning you did an AWD conversion?) and clutch. Was the swap a USDM motor with low mileage or a JDM GENII swap?
This post has been edited by Glitch001: Jun 21, 2006 - 9:08 PM
post Jun 21, 2006 - 9:13 PM
nemesis
Joined Jan 14, '06
I imported a front clip from Japan. So everything[u] is JDM. I have a 6 poc race clutch with 272 cam shafts with fuel upgrade and aftermarket stand alone computer.
nemesis
AWD converted to FWD
post Jun 21, 2006 - 9:33 PM
Glitch001
Joined May 8, '06
From Irvine
the 550's will be maxed at 300whp (please dont take it as unbelieving you, just trying to figure out your setup) Might I ask why you did camshafts but no valves when the headwork began? Im also assuming you did poly bushing and mounts to help eliminate the wheel hop problems, or at least limit it. Why not upgrade to a ct27 and give the turbo a little more room to breathe?
post Jun 21, 2006 - 9:41 PM
nemesis
Joined Jan 14, '06
My answer is simple--limited budget. I will eventually go for a bigger setup when financially possible. As for now, I did the neccessary. I have to get my car back in show condition now that I have reasonable "GO"
nemesis
post Jun 21, 2006 - 9:45 PM
Glitch001
Joined May 8, '06
From Irvine
no doubt at 10lbs its gunna be a fun ride. thats what its all about anyway right? Enjoy the boost, its addicting.
Lo-Fi Version Time is now: February 16th, 2025 - 10:59 PM
