7afe EWD, need BGB ones |
Jun 21, 2006 - 8:45 PM |
Enthusiast Joined Jun 27, '04 From ohio Currently Offline Reputation: 7 (100%) |
I need complete 7afe wiring diagrams with the II-1, II-2 and IJ1 plugs for my swap i can't find complete ones anywhere. Also are these plugs named differently than the st205 ones. thanks lance
Jun 22, 2006 - 11:17 AM |
I think you're going to have to piece most of that information together by searching the BGBs. I don't believe there are any diagrams for each of those plugs available in the online BGBs at Celicatech.com... but the information can be gathered from looking through the other pages of the EWD and writing it down as you go along. The BGBs there are missing a few pages but you can get most of the information you need from them.
This is probably going to be the best resource you find online: http://www.celicatech.com/vfewdsou/1995/95...ic/overalle.pdf http://www.celicatech.com/imagearchive/bgb...95ewd/95ewd.htm Just look through each page for a rectangle with either II1, II2, or IJ1 in it... Then make a chart of each plug's pins and you're all set. As an example: SPD, Pin 9 of plug C from the ECU goes to pin 17 of plug II2 which then goes to the speedometer in the combonation meter. B/K, Pin 4 of Plug C from the ECU goes to pin 12 of plug IJ1 which then goes to the stop light switch at the brake pedal. A manual ST would be a little bit different but that's the basic idea. Did you download the ST205 manuals in that link I PMed you? -------------------- Project ST204.5 99.88946% complete... |
Jun 22, 2006 - 10:25 PM |
yeah I got the manuals they were awsome! Kewl thanks for the info. I will let you know when I get it going. lance
Lo-Fi Version | Time is now: December 4th, 2024 - 11:20 PM |
