![]() Enthusiast ![]() Joined Apr 16, '06 From Melbourne, Australia Currently Offline Reputation: 0 (0%) ![]() |
hey guys, i was wondering if i can change the climate control lights with leds? i got a 95 ZR, so was i wondering of changing the colors, i got some 5mm LEDs the other day, and i'm not sure if it'll workor not, sorry i don't know that much about electrical and electronics, thanks in advance, cheers...
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Portsmouth, RI Currently Offline Reputation: 33 (100%) ![]() |
http://www.6gc.net/index.php?action=howto&itu=122
^that has nothing to do with LEDs, you can change the color with out them... so idk about that part This post has been edited by hurley97: Jun 22, 2006 - 10:53 AM -------------------- |
![]() Enthusiast ![]() ![]() Joined Feb 3, '05 From USA/Virginia Currently Offline Reputation: 2 (100%) ![]() |
the cc unit has a led under each button ('cept the rear window, that's a small bulb), and 3x special toyota bulbs for backlighting.
you can change the color a number of ways, but if you want an intense/saturated color, you'll need to use leds and resistors. for backlighting i used num74 led replacements (with the resistors already wired in) purchased from here: autolumination.com. then took the bulb out of it's base, bored it's holes out a litte bigger. and seated the guts of the num74 led in there. if you want i can give you a link to the diagram. |
thanks for ur help guys, i'll try and giv it a go
Lo-Fi Version | Time is now: February 20th, 2025 - 12:55 AM |
