my radiator blew, help me!!!! |
Jun 22, 2006 - 11:55 AM |
Enthusiast Joined Jan 9, '05 From connecticut Currently Offline Reputation: 3 (100%) |
i was just wondering if anyone knows if a GT radiator is sufficient for a 3rd gen 3sgte.
im looking at picking up KOYO alum radiator, but i need to know if it will do the trick. |
Jun 22, 2006 - 12:06 PM |
the koyo is huge..is should be more than enough..i would just be worried about having enough room.
we had to trim vins(shin) fan shroud to fit the turbo stuff on the 5s. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Jun 22, 2006 - 12:12 PM |
true true, i'll have to measure and see how much room i really have in there. do the KOYO's have the mounting for the fans do you know?
Jun 22, 2006 - 2:30 PM |
if you can't fit the KOYO radiator with stock fans might i suggest an upgrade to some great qualtiy super thin SPAL fans
Jun 22, 2006 - 5:24 PM |
QUOTE(celiman05 @ Jun 22, 2006 - 1:12 PM) [snapback]447644[/snapback] true true, i'll have to measure and see how much room i really have in there. do the KOYO's have the mounting for the fans do you know? yup. IIRC, they mounted just like stock. dans got the right idea, if your pocket can afford it although, ive never seen the 205 rad in person, i would "think" the 204 rad would work, although i cant say i would wanna be racing with it and stuff. i think if you look thru shin's posts, he prolly has some pics from when we did the install. -------------------- Former Team 5SFTE pro member ;)
Jun 22, 2006 - 5:26 PM |
im rocking the stock gt radiator for 2years not and never had any issues with the cooling system.
Jun 22, 2006 - 7:50 PM |
alright great. thanks guys.
Jun 23, 2006 - 1:13 PM |
i took measurements of the KOYO, and it seems almost identical to the 3rd gen rad.
sweet |
Jun 23, 2006 - 1:18 PM |
http://cgi.ebay.com/ebaymotors/94-97-Toyot...sspagenameZWDVW
i got mine from them i like it. lot bigger than stock. -------------------- |
Jun 23, 2006 - 5:42 PM |
QUOTE(x_itchy_b_x @ Jun 23, 2006 - 2:18 PM) [snapback]448106[/snapback] http://cgi.ebay.com/ebaymotors/94-97-Toyot...sspagenameZWDVW i got mine from them i like it. lot bigger than stock. looks like a good bang for the buck. got any pics of it? -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jun 23, 2006 - 8:54 PM |
sure thing ill get some tomorrow.
Jun 24, 2006 - 4:32 PM |
Enthusiast Joined Sep 9, '02 From Scranton, Pa Currently Offline Reputation: 7 (100%) |
id also like to see some pics.
Jun 24, 2006 - 5:59 PM |
little dirty but you get the idea. -------------------- |
Jun 25, 2006 - 5:09 AM |
Enthusiast Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
My GT (3S-GE) radiator was as large as the ST version here. The ST205 Radiator is about 2-3 times as thick as the old GT radiator. And thats only for the Engine/turbo IC has a separate radiator. So I dont think (depends in what climate you drive) that a GT radiator is sufficient to keep everything "cold"
Looking at the pics from Itchy, the ST205 and the one form itchy are about the same in thickness. This post has been edited by Kadett: Jun 25, 2006 - 5:21 AM -------------------- JDM Powerplant installed, BPU coming very soon!
Jun 26, 2006 - 4:53 AM |
Enthusiast Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
QUOTE(Kadett @ Jun 25, 2006 - 3:09 AM) [snapback]448626[/snapback] Looking at the pics from Itchy, the ST205 and the one form itchy are about the same in thickness. I agree- that looks almost exactly the same thickness as my ST205 radiator (heh, I got it to fit in the Camry!) -Charlie This post has been edited by phattyduck: Jun 26, 2006 - 4:53 AM -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
Jun 29, 2006 - 8:43 PM |
Enthusiast Joined Mar 17, '05 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
I ahve a Koyo unit on my ST205. It is a lot thicker than the stock rad and would be suprised it it wouldn't be able to cope with some stupidly serious power.
I'm stuck here at work for the next 17 hours so can't get any pics up until the morning. Will endeavour to do so. Gary -------------------- 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Jun 30, 2006 - 8:21 AM |
Im in search of a new radiator as well. Has some minor light brown spots ontop, no hairline cracks so far but better safe then sorry (radiator is from 1996). Only OEM Rad is about 400 euros Maybe going for a Koyo or something else.
Jul 6, 2006 - 10:36 AM |
i got my koyo rad in and i must have measured wrong cuz it is alot thicker. i got it to fit but it is very thick. i'll throw some pics up soon.
Lo-Fi Version | Time is now: November 27th, 2024 - 9:07 AM |
