> A/C causing problems..., Engine overheats
post Jun 22, 2006 - 7:00 PM
rpghermit
Joined Jun 7, '06
From Desert Hot Springs
Alright, I've already replaced the radiator. But my celica still overheats when I turn on the A/C. Does anyone have any idea what the problem may be?
post Jun 22, 2006 - 7:22 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
condensor fan is working?
post Jun 22, 2006 - 9:30 PM
rpghermit
Joined Jun 7, '06
where would that be?
post Jun 22, 2006 - 9:38 PM
Bitter
Joined Mar 11, '06
the fan infront of the radiator.
post Jun 23, 2006 - 1:07 AM
rpghermit
Joined Jun 7, '06
yes both of them are working perfectly.
post Jun 23, 2006 - 6:28 PM
CelicaST202
Joined Apr 2, '06
From Socal
did you check your waterpump?
post Jun 24, 2006 - 1:32 AM
rpghermit
Joined Jun 7, '06
it's a fairly new one. i'll check it out though.
post Jun 24, 2006 - 8:23 AM
expedition2166
Joined Jun 14, '06
From bainbridge ga
have you washed the bugs out of the condenser 7 out of 10 issues with ac / overheating is related to insuffecient airflow get a goooooood degreaser and spray the condenser down and wash it out also have you checked the coolant if theres and crusty looking goop in the radiator you'll need to do a system flush which i recomend doing any way if you haven't done it it keeps things nice n clean and a nice n clean engine is one that will go for 3000 million miles lol seriously though wash your condenser out i seen tooooo many cases where guys will buy high flow bada*s radiators to try n fix a overheating issue when all it was well was dragon flys n bumble bees over the years blocking off airflow through the radiator
This post has been edited by expedition2166: Jun 24, 2006 - 8:25 AM
post Jun 25, 2006 - 2:27 AM
rayneezy23
Joined Jun 25, '06
From Bremerton, Washington
i dont know if this is right but the same thing happen to my integra it had a blown head gasket i don't know if that has to do anything to your problems
This post has been edited by rayneezy23: Jun 25, 2006 - 2:27 AM
post Jun 25, 2006 - 9:48 PM
nightryder
Joined Sep 29, '05
From Rochester, Massachusetts
i know your a bright person so im going to spare the "check your fluids" speach. maybe you could check to make sure the thermostat is opening up, that could be your problem, cuz youd still be getting cold air, but putting way too much strain on the engine without pumping the coolant through your head.
The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed?
post Jun 28, 2006 - 6:05 PM
rpghermit
Joined Jun 7, '06
Well, I've cleaned out the condenser... I don't think that was it kindasad.gif . Next I'm going to check the thermostat. But I think it's the head gasket.
post Jul 4, 2006 - 4:08 AM
rpghermit
Joined Jun 7, '06
alright... the thermostat IS working properly... the water pump is working just fine... the condenser is clean... the radiator is new...
What else could it be?
Lo-Fi Version Time is now: December 1st, 2024 - 7:34 AM
