> Water in engine, car wont start, almost ended the celicas life tonight
post Jun 23, 2006 - 3:23 AM
Akimbo
Joined Jun 30, '03
From O-town, FL
So Iw as coming back from my ex's...driving about 60 on a country road...anyway long story short, we have had massive rain lately, i wasn't thinking of roadways being covered, but needless to say i stumbled upon one about 8 inches deep. I hit it full speed, 60 miles an hour, didn't even see it till the last second. Before i knew it I was in a 360 degere spin with half my car off the road. The spin sent water everywhere in huge amounts. When I had finally calmed down (Scared me to death, felt like the car was gonna roll and flip) I turned the car off because there was a lot of steam coming from under the hood. I turned the key but it didn't respond. It won't turn over. I think the spark plugs may have gotten wet. There's no way that enough water got into the intake to do damage.
I left the car at a locals place right by where I went off. I'm gonna go tomorrow to check the car out, it SOUNDS like I broke an axle too. But about the motor, what should I do tomorrow if it doesn't start? Can I take the spark plugs out or is that too risky? Any advice would be great.
- Ryan
aim: rkgreen04
post Jun 23, 2006 - 8:03 AM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
not much help but, that really sucks man. Nothing is worse then the feeling have having no control over something.
Spark plugs might have gotten wet....pull the whole thing out, and let them sit out and dry. Put them back in and try to start it. If that doesnt work then im not sure.
Kawi Love
post Jun 23, 2006 - 8:31 AM
celicasteve
Joined May 20, '06
From deltona, fl
i would just go back and try agian, stuff got wet, and it needs to dry out. Atleast that is what your hopeing for.
Steve
If Columbus was told, "use the search function," he would have learned that the World was flat.
post Jun 23, 2006 - 2:37 PM
Akimbo
Joined Jun 30, '03
From O-town, FL
Would the cap and rotor be a good guess?
- Ryan
aim: rkgreen04
post Jun 23, 2006 - 2:42 PM
jdg371
Joined Jun 14, '05
dont try to start it untill your sure everthing is dry!!!
This happened to my friends neon.. he ran about 6inches of water.. it wont even crank anymore... high pressure air and use it all over the engine bay.. Im not sure but does ST have long spark plug tubes?? if they do.. try taking the wires off then vacuum or blow all the water in there off
Good Luck..
post Jun 23, 2006 - 2:54 PM
DomGT
Joined Apr 19, '06
From Long Island, NY
It is very important that you give the car enough time to dry off. Before you start it at LEAST check the air filter, and pull the plugs (if water got into the engine they could be fouled). You have to be careful, IF you start the car with water in the motor you will hydrolock the motor and you'll be looking for a 3SGTE wink.gif just to get your car rolling again.
Remember mechanics can bring flooded cars back to life, your car will be fine as long as you make sure its dry.
'92 Grey Mitsubishi 3000GT SL - Sold
'96 Black Celica ST 25th Anniversary - Sold
'99 Black Mitsubishi 3000GT VR-4 - Sold
'04 E250 Work Van - Going soon
'08 Grey Dodge Charger Work Car - Ordered
post Jun 23, 2006 - 4:16 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
if you think you got water into the engine you should ALWAYS pull the plugs before you try to crank it.
post Jun 23, 2006 - 6:17 PM
trd94
Joined Jan 9, '05
From green springs ohio
if there is water around the spark plugs dont remove them with out removing the water first , check your air filter if no water got in it then your engine should be fine , your cap and rotor i would check and dry out, also check all the plugs and wire connections around the bay and your fuse box, biggrin.gif
post Jun 23, 2006 - 10:30 PM
2003cbgts
Joined Feb 16, '05
From south carolina
damn sorry to hear bout that.. hope u get it straighted out
post Jun 25, 2006 - 2:19 AM
Akimbo
Joined Jun 30, '03
From O-town, FL
im almost positive there isnt enough water that something got THAT damaged. just enough to get some things damped. But it still won't start as of today.
- Ryan
aim: rkgreen04
post Jun 25, 2006 - 7:01 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
You would only have water in the engine if the engine bay got totally flooded or you have a CAI and it sucked up the water. Normally Water splashed all over your engine and it caused some steam from the manifold.
I say take a look at your fuses and see if someting got fried.
post Jul 8, 2006 - 9:57 AM
DomGT
Joined Apr 19, '06
Update?
Lo-Fi Version Time is now: December 4th, 2024 - 3:44 PM
