> rear sway bar questions, i've cut my end links.
post Jun 24, 2006 - 1:00 PM
Tech9ine
Joined Jun 28, '05
From MB, Canada
Okay, I installed new kyb gr-2's and some tein s-techs the other day and when i was doing the rears the bolts securing my sway bar to my rear sturts were seized hard, and i rounded out the allan key slot and basically screwed myself. I decided to just cut my sway bar end links in half.
What are my options now? should i look for used ones or is there a place i can get new ones for a decent price, or should i perhaps look at upgrading my entire sway bar??? I'd prefer to go the cheapest route obviously.
Thanks,
Shawn
(on a side note, i hear a very strange clunking noise when i turn my wheels 100% to the right of left, as if something was catching. It's coming from the front.)
This post has been edited by Tech9ine: Jun 24, 2006 - 1:39 PM
post Jun 24, 2006 - 1:26 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
its because you dont have any sway end links in the rear!!! go buy some and put them on, your car is not safe to drive w/o them. did you change or grease the strut bearings?
This post has been edited by LewFX: Jun 24, 2006 - 1:28 PM
post Jun 24, 2006 - 2:08 PM
Tech9ine
Joined Jun 28, '05
From MB, Canada
strut bearing??? would that be the disc on the top of the strut assembly which gets covered by the top cap? if so, then yes i greased it up something fierce. But if its something else... then no, i did not grease it.
This post has been edited by Tech9ine: Jun 24, 2006 - 2:08 PM
post Jun 24, 2006 - 4:02 PM
you would need to completely cut the links off then install new ones.
Lo-Fi Version Time is now: February 17th, 2025 - 10:34 AM
